Engine immobilizer
Started by cesarnz, August 14, 2008, 01:02:04 PM
cesarnz
hey hitman, whats involved in re-programming things like car keys etc ?? i am a bit of a computer wiz but havent done this sort of stuff before. just curious to learn.
ta,
Cesar.
veedubman
its easy.. you just need software and hardware..
cesarnz
haha, kinda figured that.  Guess you are not a man of many words.
veedubman
well im just not all that literate..
it takes about 5 minutes..
cesarnz
thats cool mate. you can get the job done thats all the matters.
Quote from: cesarnz on August 29, 2008, 10:41:50 AM
I guess its more the fact you dont have the software or the hardware so whats the point in going into details?
omad
Just talked to Giltraps and they want $350 for a replacement key with remote, and thats without getting it encoded, or $150 without remote, can you just go to a local locksmiths and get a key from there cut?? I know the lock smith in taupo does laser cutting, will they work or does it have to be OEM??
1999 Golf GTI ABT
2009 Suzuki Jimny, 19.9% VAG and 1300cc's of off-road goodness...
Inside the key plastic end is a transponder that has to be near the ring that goes around the ignition switch and this comunicates with the ecu and unlocks it. When you get a new key it must be a key that has this transponder and maybe it has to be blank im not sure if you can recode the keys or you just get them with a number attached and youhaveto use the vagcom to change the number in the ecu to match the number of your key. get it :)
i hope i havent re said all this as i havent read the whole post.
