"safe" oil temperature
Started by 80 Vert, September 29, 2008, 07:48:45 PM
What is a safe engine oil temp and whats too hot?
Lets say you run a good synthetic oil, what would one expect to run temperature wise?
qta4
Good question John, my car has run at 150c many times, now at about 110,120 driving really hard
Aidan
Quote from: qta4 on September 29, 2008, 07:51:14 PM
Hmm, I've never seen mine past 92, running Mobil 1.
Das Auto(s): 2007 MKV GTI Manual and a random Beemer
Hoff
98 usually for me but its been up to 115.
1985 Mk2 Golf GTI
Mk1 Golf Project
MK2 Project
My gauge was at 235F today beating on it a lot, Google tells me thats 110C.
Previous with stg1 it was 200-210F max so quite an increase, not really concerned but as with any gauge you end up looking at the damn thing all the time.
Summer heat will be the test, may look at installing oil cooler if temps rise more.
Aidan
Quote from: vert1 on September 29, 2008, 08:00:57 PM
Is that on one of your Beetles, it says here that they shouldn't run over 240.
qta4
I am not too concerned with really high oil temps John,just change oil at more regular intervals
gti vr6
mine runs around 90 once warm. 135 was the hottest and that was around Pukekohe in summer
1986 Mk2 Scirocco
Quote from: Aidan on September 29, 2008, 08:05:09 PM
No, its on the Jetta.
Aircooled engines are a big no no for high temps as they are 70% oil cooled.
qta4
In an ideal world oil temp should reflect water temp, in fact many VW systems control oil temp by feeding oil through water  system.
But in modified world these temps change.
My oil temp does not reflect water temp at all, bugger.
Angle
Does it matter how hot the oil gets if it is suited to the temps (ie: not breaking down?) or is the engine limited to the heat it can handle (ie: although it's lubricated it will cook?)
Aidan
Quote from: qta4 on September 29, 2008, 08:15:10 PM
That would explain my temp. Actually remember seeing a golf at the workshop where the oil cooler had failed and had oil running through the radiator, dick head owner didn't click something was up when his water in the res tank was a different colour, and had run it for 5k after noticing it. Overheated.
Apparently mineral oil turns to varnish at around 140C so yes it will harm your engine to run it too hot.
In all my N/A cars I've ever owned the oil has always been 100-110C, I would expect an S/C or turbo car to run a little hotter.
This is where a good synthetic oil will come into its own.
Angle
Quote from: vert1 on September 29, 2008, 08:23:22 PM
Exactly, which gets back to my question that I'd love to understand. It might help me get over my obsession with using the 'right' engine oil, if I have a better handle on heat relative to the engine. Yes, the engine will make less power, and at some point will pre-detonate until it sounds like a diesel, but assumming the engine is running correctly and the timing is intact:
qta4
Vw and others use a preheat system ,connected to the primary water circuit of the car,primarily to preheat the engine oil.
But these systems often fail with many miles cross poluting engine oil with engine water, not particularly good.
As long as water temp does not exceed design temps alls cool, but with a modfied engine, a seperate oil cooller is really required.
qta4
Quote from: AngleBox on September 29, 2008, 08:27:03 PM
Dennis, i would be surprised if your engine oil exceeds 140c,for any prolonged period anyway.
I have exceeded 150 c many times, and have now fitted an external oil cooler,alls much better , but still not whrer i want temps to be.
My intercooler is shielding my radiator too much, and the only way i can overcome this problem is to redesign the whole intercooler thing, which i will do prior to next track day in Dec.
It gives a whole new appreciation to those who build a race car and all is good from day one.
Period_Correct_
pre-detonate
when the spark goes off its deflagragration...  ;D
I reckon you should try and get the oil temps as what the engine is specified to run at. as the engine is designed to work with a certain tempreture for thermal expansion... when you find that you'll find the range you're looking for.
generally the cooler the better.
robh
110C is bugger all, as Noel has stated already 150C is easily seen on turbo cars when flogged to death at somewhere like Pukey.
That said I don't think you should aim for 150C :)
I can't remember are you still running factory water/oil heat exchanger?  If so I think if you want to go to Pukey and do some flat out driving you will certainly be way over 110C by a long way.  Might pay to fit an air/oil cooler now or unplug you oil temp sender so you don't keep looking at it!
Angle
#18
Quote from: qta4 on September 29, 2008, 08:37:00 PM
Noel, my question isn't focused solely on my car, although I do appreciate your concern. The Anglia sits around 180 - 190 degrees F (about 88 degrees C max). I've installed the largest cores I could fit in the radiator frame when I rebuilt it. I'd still like to see the temps lower, and I'll have Pro-coat put their temperature disappating coating on it (thermostat is 180 degree F). That all sounds about right doesn't it Noel?
So, even if the oil doesn't break down, you could raise the temp of your engine to the point where the moving parts expand to the point that they significantly alter the internal tolerances and create such high friction that the engine fails? Is that the simple explanation?
Period_Correct_
Quote from: AngleBox on September 29, 2008, 09:57:41 PM
high temps can and will lead to many things... 1 being thermal expansion and the tolerances being over shot. but depending on some factors, detonation occurs before that. thank GOD.... so either way you're damned!
