1.8t Conversion
Started by Aidan, November 10, 2008, 04:25:53 PM
qta4
ABF,ABA,doesnt really matter, the secret to good reliable power is really good software.
And that can be a little elusive , unless you go for Link,motec, or similar
Aidan
The kit comes with a software update via OBD. I think I'm still gonna pick up the AGU, never know when you could need it :)
Das Auto(s): 2007 MKV GTI Manual and a random Beemer
qta4
Thats cool, good luck with the build
Angle
BahnBrenner don't have the software to run the ABF ECU at the moment. Last time I wrote to them, they indicated January they might have an ABF supercharger.
Aidan
Quote from: AngleBox on November 16, 2008, 07:16:05 PM
Right, that answers the question I was going to ask them. Cheers. For some reason, I think I would prefer a S/C.
qta4
I probably have the ideal setup that the 1.8t can reliably run on, off the shelf,and quite honestly is enough power.
To get more power from the 1.8t engine, i would have to lower compression and use a Link. or Motec system.
But , i am waiting for someone else to build a bigger beast.
Angle
Quote from: qta4 on November 16, 2008, 07:26:13 PM
It is a beautiful set-up; it's the whole powertrain package that makes the impression. I wouldn't mind putting something along the lines of what you've done into the GTI ..... in a few years.
Who's that Noel?  ;D
qta4
vag_nutter
Would megasquirt run a 1.8t ok?
qta4
Why on earth would anyone Megasquirt a 1.8t ,when you can get full VAG-COM  with OEM software
vag_nutter
Whats wrong with megasquirt ???
qta4
Probably nothing,except lots of dyno time and experimenting
Period_Correct_
theres no point in EFIing an engine that is already being run on the best standard engine management system around...
however the gains to meagsquirt over Bosch would be the control, however, if you are not going to be doing alot of tuning, then there is no point...
qta4
What has happened to this build?
Aidan
Two things. I was talked out of it by Dad, and also a bit with Cameron. And the parts guy closed down before I got the funds.
GTI's
What Rambo Cameron?
Tell your dad to come for a rip in my car.
It's safe, economical, loads more fun than a normal golf and i deserve carbon credits for making my own!
qta4
What has happend here?
