Polo 4.2 V8 Transplant
Started by Lee, April 22, 2009, 08:33:11 PM
Lee
Engine mounts top side
qta4
Thats so cool Lee, i know just how hard it is to feed these on Vask with photos. Good work.
Lee
Gearbox mount and below
What gearbox are you using Lee?
qta4
Quote from: Golfboy666GTI on July 21, 2009, 07:45:22 PM
VR6 box Nik, that driver side CV looks really close to the side of the block, must have taken a long time to get orientation of engine and box right.
Great stuff.
Lee
This what was cut out of the passengers side front rail.
Because the car is just over 15 years old it does not have to be front impact compliant .
The rules are fairly stiff for later 95 cars onward.
My certifier here in the Waikato was quite happy with me cutting so much-- as the left rail only holds up the bumper it's not a major
Its tight on the right side but I didn't need to modify it
Lee
Front off and on
Lee
Because the back of the v8 almost touches the bulkhead -the brake servo had to go.
Shown is a Nissan 25 mm master cylinder with pipe work to the rear remote servo .
Only the front brakes will be assisted.
Work in progress
qta4
You have been busy Lee, it must be so tight around the firewall side if the exhaust manifold as well.
Did you sort out the bonnet catch probelm?
Has anyone heard of this type of transplant being done before or is Lee breaking new ground?
VR6
I would say he's breaking new ground, great to see someone doing something different.
Looks like it has come along very nicely from when I saw it last Lee, great stuff.
Lee
You can see from this the front bank of cylinders.
My overall concern with this exercise is how front heavy the car will be.
I have reduced weight as much as possible and even had to delete the inlet manifold as it weighed 15 kg
Will be making a light weight aluminium manifold with short tracks instead of the original variable castings.
This will probably reduce the torque but I don't think power will be a problem.
Am working on the exhaust -oil external filter-brake lines -remote servo -battery relocation---
yeah --still working
Where are you putting the radiator Lee? When I saw you last I don't think you had decided?
Lee
In front like normal.
It's slightly smaller than I would like and the fan may have to work more than normal.
With 4.2 litres it's not going to be under stress as the 1.8t was.
I have just had a major problem finding a crank angle sensor as the v8 ran it's sensor on the flexie plate. Ended up with a Nissan v8 sensor that I have to adapt to the end of the cam.
There are alot of things that will require modification but the main thing now is to get it running
ritmo
Bullseye
This is brilliant!
Have you looked at dry sumping it to move some more weight?
Lee
Hmmmm interesting
I just weighed 4 litres of oil --about 3 kg--
Certainly worth investigation
Thanks
qta4
Any updates yet Lee?
If your car goes anything like mine, you will have a problem, at least  can reduce boost........... >:D
Lee
#59
Not much to report--
Just finished the exhaust extractors --working on the rear brake booster and the new inlet manifold.
Another couple of weeks it will go in for the computer to be set up.
