WTB: Air Inlet Duct (and hose) for '86 Coupe Quattro
Started by td19, May 24, 2009, 09:59:18 AM
td19
Does anyone have a rubber duct for an '86 Coupe Quattro (KV) in good condition.  It is slightly different to the one from my donor Coupe GT as there is an extra outlet connection.  I also need a replacement hose (air) that goes from a three-way plastic connector into the cylinder head. It about six inches long, external diameter 15 mm, internal diameter 5 mm, and has a right angle at the end that connects to the head. Part number is 035 103 237 EHO.
Hi Tony :)
I have several intakes for coupes in a big green bin I have here at home. You are welcome to tip it out and go through it.
