EGR Valve Cleaning
Started by 03Polo, June 12, 2009, 02:23:33 PM
03Polo
Hi Guys,
I have recently cleaned the throttle body on our 2003 VW Polo 1.4 (BBY) and noticed that it was quite dirty with oily carbon.  Where the EGR meets the TB seemed the worst with a big clump of crud.  The car has been playing up in that it is 'hot engine pinking' under partial acceleration.  The colder the ambient air the less it does it. The plugs and air filter have been replaced and there are no codes showing.  My question is, how difficult is it to remove and clean an EGR?  I have noticed that the TDi's seem to have filthy EGR's.  Would a restricted EGR cause pinking?  What is the best cleaner for an EGR?  (I have heard that Carb cleaner will damage the diaphragm??)
03Polo
Mmm... okay I didn't do a throttle body allignment as such.  The Haynes manual didn't mention anything about this!!  From what I googled on the net I assume that it is for the ECU to learn where the Throttle position is.  The car seems to be running better after the throttle body clean but I am still get the pinking problem occasionally.
Would a VW dealer scan tool/computer provide any further information from the ECU than what your average mechainc's ECU scanner can?
Has anybody done the EGR clean and seen any benefits?  Smoother running... I'm not looking for more HP just a car that doesn't sound so rough ???
Our Lupo with BBY engine used to stall at random times, now with every service I remove and clean TB - never stalled again.
Always do TB alignment too.
