Author Topic: 1987 90 2.2 engine problem  (Read 1496 times)
Tracked
« on: August 06, 2009, 07:09:12 pm »
Im looking at buying a 87 90 with a 2200cc 5 cylinder manual but theres a problem with the engine
It will start sometimes but idle rough have no power and die. It will be fine sometimes but then die after a while.
Are there any common problems that occur with these motors usually? New to audi's
cheers
Offline GTI's
Re: 1987 90 2.2 engine problem
« Reply #1 on: August 06, 2009, 07:34:41 pm »
sounds like a blocked fuel filter or weak pump.
Tracked
« Reply #2 on: August 06, 2009, 07:37:13 pm »
are there any other things that could possibly be wrong?
Dont wana buy something thats going to be expensive to fix if it turns out not to be the fuel pump or filter
« Reply #3 on: August 06, 2009, 09:02:20 pm »
Something to do with the injection?
Its a hard question to answer.
Offline qta4
« Reply #4 on: August 06, 2009, 09:07:44 pm »
What is the engine like when hot, does it start ok?
Tracked
« Reply #5 on: August 06, 2009, 09:23:18 pm »
hard to start, very tempermental when hot usually coughs and dies about a 100m down the road
Offline 5-pot
« Reply #6 on: August 06, 2009, 09:36:53 pm »
Sounds like a vacuum leak...  I had to rev mine just to keep it running when i had left a big hose off the intake manifold...
- 1990 Coupe quattro - R.I.P.
- 2005 Golf 2.0 TDI
Offline deedub
« Reply #7 on: August 06, 2009, 10:33:44 pm »
Whenever I have had rough idling and stalling it has been a vacuum leak. They can take ages to find too.
Offline 86gte
« Reply #8 on: August 07, 2009, 08:47:42 am »
Could be a vacuum leak I think, they do have issues with the idle control valve but mine never actually stalled from that, it would just idle at like 300rpm sometimes. This problem could be a combination of a vacuum leak and a sticky idle valve? Have you been over all the electrics? Just make sure all the connectors are plugged in hard and all the spark leads and distributor are clean.
Offline 86gte
« Reply #9 on: August 07, 2009, 08:48:02 am »
Where in the country are you?
Offline wilco
  • Ted the Mechanic
« Reply #10 on: August 07, 2009, 09:05:12 am »
Dont wana buy something thats going to be expensive to fix ...
This is Audi mate, no such thing as a cheap fix on these things, esp if it's a hard-to-track problem with the ignition/injection!
Good luck but yes I'd try for vacuum leaks first.
Offline stevenc1963
« Reply #11 on: September 10, 2009, 11:14:41 pm »
Check also that the oil filler cap is the right one and this it is well sealed onto the rocker cover and that the dipstick is firmly seated in its tube. Engine air pressure leaks at these points cause running faults. Keep in mind that engines are cheap at the wreckers. Volksworld in Christchurch had one that had been driven that they would take $200 or maybe less for last month.
1985 Type 85 80 quattro
1989 Scirocco GT 2010 VW Nats, Best in Show, Water Cooled.
1990 100 quattro Avant
2000 Vespa PX150E
