Author Topic: VW / Audi Pump Duse Engine Oil New Zealand 504.00 / 507.00 Longlife  (Read 7425 times)
TDi Sport
After a bit of searching I finally managed to have ordered in from Repco the correct oil for the Pump Duse engine.
Mobil 1 ESP Seems hard to find in NZ (IME) this can be ordered in either 1 or 20 litres.
At $22 a litre is far cheaper than the VW 505.01 spec.
This conforms to VW 504.00 and 507.00 spec so good for longlife service
Just need VAGCOM to switch over to longlife service
Re: VW / Audi Pump Duse Engine Oil New Zealand 504.00 / 507.00 Longlife
« Reply #1 on: August 29, 2009, 03:11:42 pm »
great find there,
will look at this in 4000km's when i do an oil change on my B6 TDI
TDi Sport
« Reply #2 on: August 31, 2009, 08:53:42 am »
Repco's on Kent Terrace Wellington have stock.
Rob Kindly programmed my car for Longlife service, not done enough miles for it to show mileage to next service, will post results when it does.
Details of Longlife servicing can be found here
http://www.volkswagen.co.uk/assets/common/content/owners/Longlife_servicing.pdf
The car is setup for under the right conditions to be able to do 32,000 miles between oil changes.
A pic of the oil sensor in sump for Longlife servicing
« Last Edit: August 31, 2009, 02:56:12 pm by TDi Sport »
« Reply #3 on: August 31, 2009, 06:21:18 pm »
Why on earth would you leave oil in an engine soooooo long??
Bad idea if you ask me.
« Reply #4 on: August 31, 2009, 07:23:13 pm »
I agree with vert, why do it when oil is cheap enough and such a small part of the amount of oil that is used in car ownership with the most part being the fuel they use.
 Clean fresh oil will make the engine last longer.
 Who needs a special thing to tell you when the oil is old when you have eyes and finger nails and a nose.
TDi Sport
« Reply #5 on: September 01, 2009, 11:29:56 am »
$600 for an Oil and filter service is the reason.
Admittedly I did do the service myself but still costs $220 dollars in parts.
It took longer to get the top and bottom engine covers off the car than change the oil.
Modern Synthetic oils are designed to do the mileage the same as the engines are designed to do 1000,000 kms before a rebuild.
If I do lots of short trips then the service will be as normal at 10,000 miles but I do a lot of runs from Wellington to the Coromandle so the engine is upto temperature for a long time which reduces wear.
But I do remember the days when My old Mk1 Escort needed a service every 5,000 miles and the engine was knackered at 75,000 miles, but that car was built in the 70s
Welcome to 21st century German Engineering.  :)
« Reply #6 on: September 01, 2009, 02:48:42 pm »
I don't worry about service schedules so much and just change oil if its dirty.
« Reply #7 on: September 01, 2009, 05:52:21 pm »
Great story for disaster, I have never been a fan of extending service intervals ESPECIALY is a diesel!
But each to their own I guess, our TDI gets serviced every 10,000K period!
TDi Sport
« Reply #8 on: September 14, 2009, 09:20:03 am »
Update:
After a long drive from Wellington to the Coromandle the car has finally figured out when the next service will be.
Interestingly after a doing short trips for a week the service changed to be needed in 17,000 miles but since doing the run home has gone backup to 17,600 miles.
So it seems to work just like the fuel computer changing to a longer distance on long runs compared to short town trips.
Will be interesting to see how it goes with my daily commute into town.
« Reply #9 on: September 14, 2009, 10:43:50 am »
why don't you change your dash display to read in km's instead of Miles?
it's pretty easy with vagcom and about 3 minutes and you are done.
Hmm, i see you get 1200km's between fill ups?
i have only managed 1100km's to the km.
What diesel are you running in your car these days?
Also do you too have the AWX engine?
TDi Sport
« Reply #10 on: September 14, 2009, 12:23:21 pm »
I'm used to miles so works for me.
I find that Caltex with Wynns Spitfire additive gives the best performance and best fuel economy.
The difference in mid range torque between not using the additive and with it is amazing.(gives me the same performance as Shell V-Power Diesel, sadly not available here)
Because there is so much more torque, you find that you use less throttle hence better fuel economy.
http://www.wynns.net/retail_spitfire.aspx
« Reply #11 on: September 14, 2009, 04:39:00 pm »
yeah i found the Wynn's diesel treatment down in palmerston north on sunday, put some in and drove the car back to auckland. Straight.
I have tried the Mobil diesel, and found my engine to be way quieter than with caltex diesel.
Will however try the shell V-Power diesel next, give it ago. All be it the first time in 15 years i have ever tried shell petrol/diesel ever.
Offline Simon MkII
« Reply #12 on: September 14, 2009, 05:14:25 pm »
I think the Shell v-power diesel we get here in NZ is just normal diesel like everywhere else.
Mazda Mx5
TDi Sport
« Reply #13 on: September 15, 2009, 08:26:04 am »
Shell V-Power Diesel is not available in NZ and after speaking to Shell management wont be available in NZ.
Shell V-Power Petrol in NZ is only standard 96 octane where in Europe it is 98 octane
The only high octane fuel I found when I was running a WRX before the Audi arrived was BP Ultimate at 98 Octane.
Yes Caltex diesel is noisier than all other diesels but more kick and free to rev  ;D with a boost at 4000rpm in my engine.
Offline 5-pot
« Reply #14 on: September 15, 2009, 08:36:20 am »
There's Mobil 98 too and apparently Gull does a 98 octane ethanol mix or something...
- 1990 Coupe quattro - R.I.P.
- 2005 Golf 2.0 TDI
SteveC
« Reply #15 on: September 15, 2009, 09:02:38 am »
I have been using Gull 98 almost exclusively in the GTI, it has 10% whey derived bioethanol, using otherwise waste products, so it's more sustainable than some of the other bioethanol sources
our local BP stopped selling 98 because supplies were not reliable and according to an earlier thread on VASK, Mobil's 98 is lower octane modified with a booster
Gull do a biodiesel blend in Aussie, but not here and some local Gull stations have a 10% bioethanol 91 blend
Offline Simon MkII
« Reply #16 on: September 15, 2009, 10:35:48 am »
Gull Force 10 I think it's called, 98 octane with 10% ethanol.
Mazda Mx5
goldb51.8T
« Reply #17 on: September 17, 2009, 02:01:12 pm »
yip and a mate of mine had it tested and found its close to 100 octane
Offline 5-pot
« Reply #18 on: September 17, 2009, 02:07:03 pm »
And people say booze is bad for you  ;D
- 2005 Golf 2.0 TDI
goldb51.8T
« Reply #19 on: September 19, 2009, 05:19:58 pm »
just filled up on this the other day and i cant tell the difference, typical me thought id check if my cars approved to run it AFTER already filling up and what do you know. its not!
im not worried but dont think ill use it again
