A4 1.8Tq
Started by Rusty05, September 13, 2005, 08:42:53 AM
Rusty05
Hi guys,
I am new to the world of VAG cars and the forum. I have just bought a '97 A4 1.8Tq. I was looking at evo lancers, but a friend had a 98 GTI Golf that i liked so when the opportunity came up to buy a straight A4 1.8Tq, i thought "why not get some thing different?". Rex from quadring (thanks for your time on the phone the other day) suggested that i join the forum. So here i am. Now i have got the A4 i have realised that they are pretty mild out of the box. I don't own a money tree but i do have a couple of grand to throw at it straight away. Any suggestions? i thought i might start with the wheels as it has some nasty alloys on it and snow tyres(?!)...
Turbo
good choice. A4's rule, in my humble opinion.
not biased or anything.
for a power upgrade get that sucker chipped. (i think rex has AMD chips - is that right?)
or to make it look less dadsy lower it, it'll improve the handling tenfold.
beeker
I would suggest, in order:
1. Chip it + fresh TT BPV (TT BPV is cheap)
2. nice Wheels (widest is 225 without rubbing)
3. Suspenson (suggest H&R Coilovers)
4. Exhaust, but dont do the DP unless your gonna remap
5. Body kit
and if your serious...
6. Ko4 turbo swap + Ko4 chip (~230/240hp)
7. Brake Upgrade (slotted A8 rotors with TT carriers for the look, or stoptechs for track work)
13 TR86 race car
2018 Highlander
2017 Outback
Rusty05
Thanks for the input. A couple of questions...
1. Wheels. 17's or 18's? The car is going to see a bit of gravel (read 'potholes') so I'm not sure if 18's are going to leave me much rubber. Plus, it seems that if you go 18's, you almost 'have' to lower it as that size wheel can look odd unless its sitting in the guards. Does anybody else think that is a valid comment?
2. Lowering. I am already scraping occasionally on the front (see 1). I cant imagine dropping the car anymore than 20-30mm. What has everybody else found to be successful?
3.Brakes. A8 rotors and TT calipers. Is this a "bolt on" upgrade?
Any info greatly appreciated...
Turbo
Quote from: Rusty05 on September 14, 2005, 08:18:31 AM
do you have a front lip spoiler?
mine's lowered quite a bit (95mm clearance) and i don't have any problems until i encounter steep driveways and that's really just because of the spoiler.
even on most dirt roads it's fine (unless it hasn't been graded for years and the tyre channels are 96mm lower than the centre of the road.
beeker
1. Personally I would go with 17", over to you. Get something nice and lite, maybe some BBS.
2. TBA, my A4 has the Quattro GmbH suspension, as its the Lemans. But with coilovers, you can adjust to suit.
3. There is allot on www.audiworld.com on this. You use std TT carriers, A8 rotors, and its a straight bolt on, other than the smallest of filing req'd. Believe there is a FAQ on it. It wont compete with a proper big 4pot brake upgrade, but could be a good mid ground upgrade.
13 TR86 race car
2018 Highlander
2017 Outback
Rusty05
Hmmm... 17" could be the go. I can hear an extra 35HP calling pretty strong too. Aaarghh!
Quote from: beeker on September 13, 2005, 05:34:27 PM
5. Body kit
What is a BPV?
Rusty05
ByPass Valve I assume. Japanese car lovers call them Blow Off Valves. But I think the Euro cars return the air to the air intake enclosure, whereas BOV's generally vent the excess air into the engine bay. Am i right? ???
taupoq
yep also known as a wastgate
