Odometer probs on mk2
Started by likegolf88, January 10, 2005, 12:05:14 PM
likegolf88
The other day i came across this beaut white 16v mk2, i had a bit of a nosey at the odometer and it was reading 102k or something. Long story short, the owner reckons it just stopped on him "a couple of years back"!?. ( if this is true then the car is a steal for $1800)
Is it an accurate statement to say most odometer probs are pricy to fix?
robh
does the speedo work?  if not maybe it's just a simple cable snapped issue?
the little gear that drives the odometer is probly cracked and wont drive the numbers it will cost 100 dollars if you take speedo out and take to the guy by the gas station up newton gully. sounds like a good buy tho he may have done 80 thousan miles in the last two years who knows? if its tidy and goes well, buy it.
bsting
Even if its on 200ks for $1800 its still not bad price.
Prob interior is poked - sunroof ? leaks ?
likegolf88
Quote from: robh on January 10, 2005, 02:06:01 PM
does the speedo work?? if not maybe it's just a simple cable snapped issue?
No it doesnt.... this sounds promising, thanks for the help rob
likegolf88
Quote from: BSTING on January 10, 2005, 04:42:49 PM
It's a white 4 dr 87' with no sunroof, full leather interior, door cards etc (drivers seat bit rough as usual), Power windows (mostly working, needs TLC), power steering, exterior needs a clean, new tyres, very cool mags (14' or 15's) This car is very nice, when i got inside it only faintly smelt damp and he told me he had not been in it for a while, so it wasnt aired out..... It is possible the gearbox or linkage is bung, but it may only be "character" who knows....
The cars on the shore and i'd love to take it somewhere to have a look at it but as it's got no warrant it might be difficult. Only the most forgiving? :police: wouldn't fine me for africa if i was pulled over right?
make sure that damp smell isint coolant leaking out of the heater core. Id like to go look at this car with you some time if you want it does sound promiscing, however if its been Deregestered its only worth $500 max if it drives real good.
robh
be careful, if it's deregistered you won't be able to register it because it doesn't comply with frontal impact rules, unless you wait until 2007 when it will be 20 years old and then you'll be ok.
rambo_005
Unless it has previously been registered in NZ??
robh
not sure, maybe your right? just check it out before you buy.
Rambo is correct if its been regestered in NZ before it dosent need to have impact frontal thingy even if it gets dereged its only for new overseas imports.
Rossi
If the dampness is due to heater core leaking its a long but not overly difficult job to replace it, you have to take the whole dash out.  A linkage bush kit did wonders for the gear change in my old 16v, cheap and easy fix (If its only the linkage... :-\)
2001 S4 Avant.
Corrado 16v - BR Motorsport ported KR 1.8l head with 284deg schrick cams, 9A 2.0l block, Milltek headers, K&N filter, 40mm lowered on PI springs/Boge shocks + VR6 strut mounts, front poly bushes, 280mm G60 front discs, 16" Porsche replica mags.
likegolf88
#12
Quote from: Rossi on January 19, 2005, 01:01:10 PM
If the dampness is due to heater core leaking its a long but not overly difficult job to replace it, you have to take the whole dash out.? A linkage bush kit did wonders for the gear change in my old 16v, cheap and easy fix (If its only the linkage... :-\)
thanks guys, after i purchased my mk2 i bought a linkage kit for it, the guy installed for me but it made very little difference (except for the lighter wallet.....) maybe it just needs a slight alteration i dont know. I dont think its the gearbox so thats good.
dubstar
There's a partial kit and a full kit.  The partial kit will only solve part of the problem.  You could also go for a short shifter and weighted rod, which made a huge difference in my car.
likegolf88
Is it very hard to install? im a green enthusiast so....maybe an out of 5 rating?, will it be in a haynes manual?
Thanks
dubstar
Short shift kit is a 1.5 out of 5 for difficulty. i.e. really easy.
likegolf88
#16
Nice? ;D, sounds good, but by continuing to take this thread off topic ;),did you import your's?, i understand the prices vary, is the quality worth the price? or is there cheaper/ better places to import from.
http://www.neuspeed.com/products/product_details.asp?app=22|G2&type=3&ltype=ns_euro&p_id=501
http://www.neuspeed.com/products/product_details.asp?app=22|G2&type=3&ltype=ns_euro&p_id=461
Period_Correct_
that short shift kit, makes alot of difference...
likegolf88
Quote from: NasTnaS on March 01, 2005, 12:09:16 AM
cool but does it have to be neuspeed?.... is your's?
dubstar
Mine is a missing linkz kit.  Cheap, but good.
