Author Topic: Window Regulator  (Read 1395 times)
Offline Y0RKI
  • Resident Fiat Freak
  • Fiat, Alfa, Dodge, Chrysler, Jeep specialist
    • Andrew Simms Botany
Window Regulator
« on: May 05, 2010, 10:40:39 am »
I think the passenger side front window regulator has decided to give up the ghost in my ex's mk3 GTI, dont suppose anyone would have one kicking around would they?
The motor sounds to be trying to work but the window doesnt move and is jammed in place, cant manually lift or drop it!
Any help appreciated!
Everything is for sale, you just have to offer the right money
2002 Maserati 4200 Spyder
2006 Alfa Romeo 147 GTA - For Sale
2001 Fiat Coupe 20Vt Le - gone
1998 Fiat Bravo HGT - gone
1996 Fiat Coupe 16vt - gone
1990 Fiat Uno Turbo - gone (to heaven)
1986 Fiat Uno Turbo - gone
Re: Window Regulator
« Reply #1 on: May 05, 2010, 11:08:26 am »
Get a new regulator from Giltrap, same price as qualitat. They only sell genuine now as the aftermarket crap lasted 5 mins.
 Bout $140 or something maybe 180....I cant really remember.
 Lube your window guides.
Offline HaNs
« Reply #2 on: May 05, 2010, 11:27:16 am »
$180 for the last 2 i got from GT.
Offline Y0RKI
« Reply #3 on: May 05, 2010, 12:57:17 pm »
hmmmm would seem that the motor is actually stuffed, not the regulator.
Just want to at least wind the damn window up so that it is securing the vehicle as it is parked outside on a night!
Offline deedub
« Reply #4 on: May 05, 2010, 01:15:27 pm »
If you can hear the motor it is the regulator that is gone.
Otherwise it could be the motor or the controller. I have a spare motor you can have cheap.
Don't wind the window up, if you manage to wind it up then can't get it down again you have to break the glass to get the regulator out.
Offline Y0RKI
« Reply #5 on: May 05, 2010, 01:36:51 pm »
the motor just clicks when you try to move it either up or down.
Where abouts are you to come for the motor?
need it asap really
« Reply #6 on: May 05, 2010, 03:06:07 pm »
need it asap really
Check the wiring between the door and the body of the car. Pull the cover back and have a look. I had this issue with my old VR6 and it was just a broken wire.
« Reply #7 on: May 05, 2010, 03:19:46 pm »
If the motor clicks its usualy the regulator cable is all munched up in the pulley wheel, but yes as Golfboy said the wiring between pillar/door does happen often too but window will be completely dead.
« Reply #8 on: May 05, 2010, 03:33:31 pm »
wot vert said.
 its usually the reg.
 i have got them out with the window up im pretty sure ???
« Reply #9 on: May 05, 2010, 03:36:16 pm »
Yes, but a bitch to do.
« Reply #10 on: May 05, 2010, 03:58:31 pm »
So which job on cars isn't a bitch vert >:D
Offline Y0RKI
« Reply #11 on: May 05, 2010, 04:13:26 pm »
Cheers guys
thanks Nik, i'll have a proper look on friday when i have the car at home and chance to get into it.
« Reply #12 on: May 05, 2010, 04:38:50 pm »
All this trouble for an ex Clive? She must be good at baking ;)
Mk1Golfman
« Reply #13 on: May 05, 2010, 09:42:27 pm »
Had same fault on mine, window just clicked when door was shut, when I opened the door, then the window worked. I found the earth wire in the door wiring had half broken, causing the fault, soldered wire back together and all good, easy cheap fix if yours is the same.
Offline tonka
« Reply #14 on: May 10, 2010, 01:22:04 am »
Pick a part Mangere have a mk3 golf. Pretty sure the Regulator/motor hasnt been ravaged out of it yet. $35 DIY
Offline b0000st
« Reply #15 on: May 10, 2010, 08:23:41 am »
If the windows up and you cant get it down you just have to cut the cables on the reg and then you can push the glass down and undo the clamps. I have managed to undo the clamps with the window up too but you need "spaz" hands to get in there  :P
Matt
