Author Topic: Servicing 6n auto  (Read 2980 times)
Offline captncrash
  • 16v
Servicing 6n auto
« on: May 18, 2010, 05:35:43 pm »
Is changing the auto fluid on a 6n polo difficult? I've done it on older Auto's but I looked in my haynes manual and it tells me its a sealed unit that does not require servicing? Others have mentioned servicing them....
Can anyone let me know how this is done?
Many thanks :)
Re: Servicing 6n auto
« Reply #1 on: May 18, 2010, 07:53:54 pm »
Its not a sealed unit and it most certainly needs servicing!
Idealy you need a hoist to do it on but honnestly to make things easier take it to auckland automatics.
6N auto's have a mesh screen filter that should be washed so there's no need to replace it.
Offline captncrash
  • 16v
« Reply #2 on: May 18, 2010, 07:57:21 pm »
Hi Vert,
Thank you for the reply, great to know.
I'm in ChCh and have easy access to a hoist so I would like to give it a go. Any idea on how you tell when its full of fluid? or how much it takes?
Many thanks
« Reply #3 on: May 18, 2010, 08:21:19 pm »
fill with 2 ltrs dextron3, start engine in neutral with drain bung out- keep filling till it starts to run out.
Wait till it stops running out (dripping is ok) replace drain bung and switch off job done.
I would service every 20,000ks.
Offline captncrash
  • 16v
« Reply #4 on: May 18, 2010, 08:35:35 pm »
Great info thanks :)
I take it the drain bung it the plastic red cap plug on the end the short tube coming off the lower part of the box? and it is filled from this point also?
« Reply #5 on: May 18, 2010, 08:51:07 pm »
no, drain bung is in bottom of pan.
Red cap thing is the filler.
Offline captncrash
  • 16v
« Reply #6 on: May 18, 2010, 08:56:48 pm »
Wow, okay cheers, I would have thought it would just all pour out of the drain bung if it was left off while running :) I'm sure it will all make sense when I get it up on a hoist and check it out
Thanks again
« Reply #7 on: May 18, 2010, 09:00:16 pm »
I would explain if I could be bothered  :laugh: but just trust me instead.
btw, you need to take entire pan off and filter off to drain fluid, clean filter etc etc.
Longer you can leave it the more will drain out.
Offline captncrash
  • 16v
« Reply #8 on: May 18, 2010, 09:02:50 pm »
Will do  :) Ill let you know how I get on, car has just done 100kms and I doubt it has been changed yet :-\
Thanks again
« Last Edit: May 18, 2010, 09:05:54 pm by captncrash »
Offline captncrash
  • 16v
« Reply #9 on: May 19, 2010, 09:40:44 pm »
Completed this tonight, thanks very much for the advice
It all went well and is driving smoother :)
« Reply #10 on: May 19, 2010, 09:45:15 pm »
I would do another in 5-10,000ks and add a bottle of lubeguard.
Dirty black smelly oil? they usually are.
Offline deedub
« Reply #11 on: May 19, 2010, 09:45:44 pm »
I thought your polo was a manual one?
steve03
« Reply #12 on: May 19, 2010, 10:27:42 pm »
Hey john, just to clarify, these trans filters  dont need to be changed? just cleaned and re-used?
thanks (even after 100ks' of not being changed)
« Reply #13 on: May 21, 2010, 07:47:49 am »
On a 6N Polo, no need to change just clean.
On a Golf always replace.
« Last Edit: May 21, 2010, 11:06:26 am by 80 Vert »
steve03
« Reply #14 on: May 21, 2010, 08:33:42 am »
cheers john! just saved me $110..
Offline captncrash
  • 16v
« Reply #15 on: August 22, 2013, 08:35:13 am »
Big Ups to  Vert!
Just used this guide again on another polo and the result in performance of the trans is night and day!
will run another change after a few thousand kms as of course you can't get all the old fluid out first time
