Author Topic: Remapping in New Zealand.  (Read 17255 times)
Re: Remapping in New Zealand.
« Reply #60 on: November 30, 2005, 07:52:00 pm »
Yes , Mr Bob homewood and his crew now handles all AmD NZ enquiries.  They are a very professional team with the correct tools and even a dyno.
rest assure your vehicle is safe with him
Thats good to know.
Are you connected with him ? I just notice your AmDxx Logon
urq20v
« Reply #61 on: November 30, 2005, 08:14:32 pm »
Its Ching.
« Last Edit: December 01, 2005, 08:42:54 am by urq20v »
amdap
« Reply #62 on: November 30, 2005, 09:34:04 pm »
hey its Rex ;D
hitmanGTI
« Reply #63 on: December 01, 2005, 07:50:10 am »
Well well ching.. you dissapeard for a while.???
So many questions to ask and you dissapeard  :(
lol
welcom bk
eddyg
« Reply #64 on: December 04, 2005, 10:22:03 am »
I'm definitely considering a haldex controller but should I be looking at modifying the factory suspension first as well? Also eddyg did you get your fmic installed here? Just curious as keen to get one.
BTW. It appears that APR in Oz are now doing an FMIC. It looks nicer than the one I've got, it integrates better with the bumper. With my FMIC you have to remove the metal bump bar, which I wasn't happy with. It's announced on the Ozzie Audi forum:
http://www.ozaudi.com/nuke/modules.php?name=Forums&file=viewtopic&t=5636
Again, I'm not sure that this is needed by your average NZ car, only if you have lots of hot weather and or do drag racing.
Cheers, Ed.
VB
« Reply #65 on: December 04, 2005, 11:03:20 pm »
Thanks Eddy. What is everyone's thoughts on hybrid turbos? Found a guy that sells k04s with a larger compressor for $1650. Options include port/polished turbine housing ($125), ceramic coating ($100), and clipped turbine wheel ($100).
Should prevent the lag from upgrading to a larger turbo but not as proven.
http://buehnengineering.com/forums/viewtopic.php?t=37&sid=1cd5b81bc28914fbd9219445b1e77893
« Reply #66 on: December 05, 2005, 06:27:04 am »
My concern would be getting a custom MAP for it. I'm not aware of anyone in NZ that can cutom chip tune modern VAG cars.
For clarity, yes, they can install already created MAP's for OEM setups, but not cutom Dyno one off's.
hitmanGTI
« Reply #67 on: December 05, 2005, 07:25:07 am »
If you use a Ko3 Hybrid you wont need to be remapped.. flow of turbo is being increased with the reduction of heat. (or so they say anyway)
If your going Hybrid in your car.. it needs the K03 Exhaust Side and the Ko4 Compressor Side..
You increase the Exhaust side to K04 they say it wont function any more
AmD have maps off the shelf for the Hybrid turbos and even maps for the bigger turbos if you look on their website
« Last Edit: December 05, 2005, 07:27:16 am by HitmanGTI »
VB
« Reply #68 on: December 05, 2005, 04:42:59 pm »
Thanks Beeker I was also worried that I wouldn't be able to get a remap done for it. I mate wait until I hear of some one in Australia succeeding with the set up and then ask them what they've done etc.
« Reply #69 on: December 05, 2005, 05:26:49 pm »
If you adapt any part of the cars engine, you will technically need a remap. If its a minor change, maybe not. To get performance from any mods or keep within safe tolerances, any any reasonable change will require a remap. Remember, under WOT you're working of a MAP, and not dynamic.
Classic example if someone at work that professionally installed a larger turbo on their Evo. They now do the 1/4 1 second slower that before. Once a custom computer is installed, it'll go ~1/2 faster than before. Another example is when I installed a Milltek exhaust and DP on my MTM A4TQM. It dropped !! 8KW over std. It needed a remap.
« Reply #70 on: December 05, 2005, 05:29:45 pm »
AU generally gets the same ECU#'s as NZ, ie Eurospec. Generally AU will be a good source of compatible bits. Their fuel is also ~similar.
GIAC has a good name also. Have a snoop on www.audiworld.com and post some queries on the Australian forum.
hitmanGTI
« Reply #71 on: December 18, 2005, 11:22:13 am »
Good call! Sounds like a cheap gain.  ;D
It;s great that cats aren't compulsory here like in the UK. Would it be worth putting in a resonator in the place of the cat or go for straight pipe?
Put the resonator in other wise your car will sound like a honda
vs2
« Reply #72 on: January 03, 2006, 07:56:17 am »
None of you mention Paul Watson. I use him for knowledge and bits and pieces on the RS6. Don't know him that well but seems like a nice guy. He REVO'd me.
http://www.eurotechnic.co.nz/the_people.html
hitmanGTI
« Reply #73 on: January 03, 2006, 08:09:57 am »
Ive mentioned him in the other threads!!!! :D
