Standard Audio
Started by MRVR6, January 11, 2005, 03:06:16 PM
0 Members and 4 Guests are viewing this topic.
MRVR6
Hi, do you guys have Clarion as your standard Audio?
Nope, but it depends on where your car was sold new.
old4130
Hi,
Mine does have Clarion, its a Mk3 GTi, japanese spec.
Its pretty basic, & its about to go
David
2005 Audi A4 1.8tq S line
1997 VW Golf GTI 16v
2011 Keeway Matrix
bsting
Yep, VW badged clarion - changed to Blaupunkt.
My NZ new car was fitted with a factory Blaupunkt tape player.
I think in the UK most Mk3s had Sony gear in them.
dimistyle
My Jap import Passat HAD :o a Sony MD player but looked like a Bluapunkt - all black.
It was also matched with red button lights and blue screen with dimmer control with the dash lights.
Now been replaced with a Panasonic with red button lights and blue screen, but alas No dimmer control ::)
Blaupunkt do have some unit available in NZ to match VW/Audi interiors but a bit pricey for what you get.
bsting
Quote from: dimistyle on January 11, 2005, 05:42:45 PM
Nobody regrets buying quailty - Blau has wicked radio reception - even out in the wop wops.
dimistyle
You mention reception, all Passats have antenna boosters installed in the roof under the antenna, If you use the stock radio with a band expander (Jap radio) or an after market radio you need to still send 12v up the antenna cable to power the unit, this is an after market part required to be installed in line with your antenna with a 12v  connection ::)
Are Golfs the same ??? do they have an antenna booster. I have a part no. somewhere if required by anyone having AM/FM reception problems.
Just a thought...
bsting
Quote from: dimistyle on January 12, 2005, 09:33:58 AM
You mention reception, all Passats have antenna boosters installed in the roof under the antenna, If you use the stock radio with a band expander (Jap radio) or an after market radio you need to still send 12v up the antenna cable to power the unit, this is an after market part required to be installed in line with your antenna with a 12v? connection ::)
Just a thought...
yes mk3 beesting is powered.
MRVR6
too bad mine is Jap import so it only go to 90 FM
dimistyle
Quote from: MRVR6 on January 13, 2005, 08:36:52 AM
Are you keeping the Clarion?? or changing the the unit out.
A good band expander and an antenna 12v injector, made by Bosch for VW/Audi powered antenna, I picked mine up from Rapid Radio for about $60. And you can continue to use you stock head unit. ;D
bsting
Get 10hz band expander - ok cheapies out there for $10 - 20.
10hz ie 95fm your display shows as 85fm.
