Lupo coilover query.
Started by lupi, July 19, 2010, 06:43:51 PM
lupi
Hey guys, I have a set of v-maxx coil overs which were very kindly fitted for me. Does anyone have any ideas why the back/rear would still be sitting high even though they have been wound all the way down. Has it got something to do with the rubber washer at the top? Also I can get 2 fingers between the guard and wheel on one side and 3 three on the other. They were professionally installed, but perhaps they need to have a wee mod done to them?
Thanks for any help  :-*
Regards,
~Luke
Are the Lupo specific coilovers?
Also, who fitted them for you?
Trofeo
designed for rally, or rallycross applications  :P
that said, it should sit level regardless. i'd get them checked out asap.
HaNs
Fronts at the back and backs in the front comes to mind...
You should be able to wind it right down until its scraping on everything  >:D
lupi
Maybe vmaxx are no good? They're super bouncy.... Perhaps a fail on my part  :'(
HaNs
Will try and drop by some time and have a look at them Luke
Filx
Quote from: HaNs on July 19, 2010, 08:11:01 PM
You've seen Lupo suspension right?
HaNs
Quote from: Filx on July 20, 2010, 09:52:21 AM
Never worked on one
Other thing is they could be at their TUV limits. Funnily enough its the first comment about them being bouncy from nz customers.
lupi
Yeah, i'd love you to stop and have a look at them. Would today work, as I cannot really drive the car till it's sorted.
Do they have an unusual set up Phil?
Simon MkII
Quote from: Golfboy666GTI on July 20, 2010, 10:47:51 AM
Macpherson strut at the front, seperate coil and shock at the rear.
Mazda Mx5
Quote from: Simon MkII on July 20, 2010, 11:48:40 AM
Like a Mk4 Golf then? So you cant adjust the rear suspension height of the Lupo?
Should be able to, good coil over sets have threaded tubes under the rear springs.
GTI's
So who installed them?  The V max are only height adjustable not adj dampening right?
RS4
Remember the rears will only drop 60mm max, if you go past them the shocks will lose all the travel and will make it bouncy. Have you measured the actual drop? And was the drop from std springs or lowered springs?
Audi RS4 450 BHP, Milltek, intake, remapped (sold)
VW Edition 30, 307 BHP remap. Manual. (sold)
Audi S6 V10, Milltek , Audi A4 B8 (sold)
VW Golf MK6 Gti, Black
Skoda Octavia vRS TDi, Blue, Coilovers, Mapped, 19's SOLD
Audi B7 A4 3.0 TDi , Mapped, more to follow
I fitted them.
He seems to be sorted now.
lupi
I had to remove the adjustable platform from the rear. Thing was as high as a kite. In hindsight I should have just cut the springs like choppy told me >:D
Quote from: lupi on July 20, 2010, 10:17:18 PM
So were the coilovers you used in your Lupo made for a Lupo or another car?
lupi
Yeah they were Lupo specific. Just seems that they have used the wrong rated spring for the set up. Don't get me wrong, I am happy with my v-maxx set up in my MK2, but this seems like a pretty big fail in the Lupo coilover department.
Filx
Maybe take the rear spring into Stocks, tell them the weight of the car and the height you want and see if they have something that will suit in a shorter spring. Then you can re-install with the adjustable perch.
