Author Topic: wastegate cap needed  (Read 1351 times)
snowtyres
« on: July 28, 2010, 11:01:31 am »
I need a wastegate cap assembly to replace one our S2 that has been "modified" (drilled out top and huge bolt fitted) by previous owner when superchip installed.
required for S2 but same as RR on urq
Re: wastegate cap needed
« Reply #1 on: July 31, 2010, 10:39:54 am »
Lucky you. I'm in the same boat. What are you going to do about replacing your chips? Is your S2 a 3B or a ABY?
Offline John Stone
« Reply #2 on: July 31, 2010, 03:19:03 pm »
For a wastegate cap, check Peugeot parts......
86 WR
04 A3
05 V50T5
« Reply #3 on: July 31, 2010, 08:03:49 pm »
Really? What Model Pug John?
Offline John Stone
« Reply #4 on: August 01, 2010, 07:41:54 am »
Oooopppss, meant Citroen - recent reading suggests CX 2.5GTi Turbo 2 possibly Turbo 1, here or Australia
86 WR
04 A3
05 V50T5
« Reply #5 on: August 01, 2010, 12:30:48 pm »
snowtyres
« Reply #6 on: August 05, 2010, 12:43:06 pm »
our S2 is ABY
ECU has now been rebuilt in UK by
Paul Nugent       http://S2central.net
Found a replacement ECU cap in UK
should all be back together again at the end of next week
« Reply #7 on: August 05, 2010, 03:07:01 pm »
our S2 is ABY
Lucky bugger, Ive been looking for a new cap for my RS2 (ADU) because of the same issue. How much did you pay for the replacement cap?
Are you on s2forum.com?
snowtyres
« Reply #8 on: August 05, 2010, 03:42:13 pm »
secondhand cap from ebay was only was about $100.00 with airmail postage
Is this good or bad price?
I will not know until I receive it next week
