mk3 Tip
Started by bsting, January 12, 2005, 12:12:20 PM
bsting
Try this -
Lock car
Put key back in drivers door
Turn to unlock - & hold
On some mk3s windows will drop  ;D
Reverse to reset
But you knew that a
rambo_005
On the old 1991 Passat when you lock the car and hold the key the windows all go up.
Good thing to have if you notice one isnt up ;)
MRVR6
what a great info. Thanks guys. I will try mine tonight.
MRVR6
hey, since we in this subject, can the admin please make this a sticky so that whenever someone found other "tip" they can post it here??? This will help to un-mystify VAG car. Cheers.
MRVR6
I have tried it and the window of driver, front passenger and the left back passenger went down but not the one on the back of driver. Is it normal? or should all four go down?
Quote from: MRVR6 on January 20, 2005, 04:31:35 PM
All four should go up and down.
Have you ever have any problems with your windows before?
MRVR6
i try it one more time. I do notice that the window sometime play up :(
MRVR6
nope it still doesn't work. Guess I have to live with that. Too afraid to go to dealer to fix it. It still can go down when I used the inside button.
1.8t
This is a cool feature, used it today a few times.
Nice tip!
Dudlee the 86 318i
rambo_005
Mum's new A4 does it too, kinda handy in this insane heat we're having here at the mo.
that window not working could be the switch even tho hes using the key to use it. as they usually only have one relay for all the windows so if you got a relay prob none of the windows work. i can fix these relay if anyone has a prob. Also can usually fix the switches. rear windows crap out cause they dont get used much. Give the switch a firm tap to try and work it. Also when windows are down spray crc or silicon down all the window tracks to keep windows from sticking.
mk3 gti
I tried this all the windows went down but the switch inside the car will not work for the left rear
is it the switch or something else
bsting
Quote from: mk3 gti on February 10, 2005, 09:35:58 AM
Check kiddi lock on inside of door.
AndyS
Quote from: BSTING on January 24, 2005, 10:40:53 AM
Common mk3 fault in rear windows (relay) avoid useing as might not come up.
But if jammed in down postion - drive over pothole? - should now work.
My mates Mk3 GTi 16v rear left window will go down but won't come back up.  I'm guessing this is the same thing?  Does anyone know how to fix it or does it need to be taken in somewhere?
old4130
Hi,
Had the same thing with my Mk3 GTi 16v this week.
Broken window regulator. Giltrap say quite common on Golfs 95 - 2000.
Sure VAG build these things in on purpose to keep their service depts going.
2005 Audi A4 1.8tq S line
1997 VW Golf GTI 16v
2011 Keeway Matrix
MRVR6
Quote from: X 130R on February 27, 2005, 02:07:13 PM
Tell me about it!
