Audi coupe rally car build
Started by groupb4ever, November 13, 2010, 05:50:46 PM
groupb4ever
Bet that's fun with 400hp!
Show us the engine again all finished!
groupb4ever
inside
groupb4ever
front
Long Black
Looks like most fun you can have with your clothes on!!!
1999 B5 VW Passat V6 Syncro Wagon - Black...gone
2011 B8 Audi A4 S-line Avant Quattro 2.0T - White..Gone
2008 Mk5 VW Golf GTI - Black
2012 B8 Audi S4 Avant - Brilliant Red
nacnud
Whatcha Think?
Flickr
1991 Jetta ABF
CGK
groupb4ever
After all the hard yards, time to play.
So is it just a standard KG 10v with a bigger turbo and after market EFI?
182 up too 400hp?
Wicked crap.
That looks the part. How does it go and handle?
groupb4ever
Nothing standard in this engine, cam, pistons, major head work, chrome molly flywheel, paddle clutch, 630cc injectors, megasquirt ecu ,mods to turbo, coil per plug, 25 lb boost, overhead intercooler, etc etc, as for handling, its just the beginning here, have started with 3/4 degree negative camber both front and rear, 1 mm toe out in the rear and 3mm toe out in the front, front spring are 240 lb and perfect as for the rear at 120 now and not happy, have ordered 160 lbs to fix this problem, very happy so far, ran warm at our first rally, so have a 4 row alloy coming from aussie. Have another rally in two weeks, will update after.
Cool.
Thanks so much for sharing this project with us its one of the best on Vask that's for sure.
Love the home made Kiwi styles.
00quattro00
What turbo are you running? 400hp from a 10v is pretty good
qta4
I have never studied 4wd suspension, my experience relates to rwd and fwd.
But with 1mm toe out at the rear and 3mm toe out at front seems huge to me.
I also remember that the rear toe out had an amazing effect on our imp, i think we settled for neutral rear toe after many runs, but we found it critical.
With the front 1.5mm toe out worked well, but the car would have been a handful if we ran that much toe.
groupb4ever
Second rally last weekend and its a good feeling to have subarus and mitzes behind us on the finish board. New radiator fixed all cooling problems and car run great.
The turbo im running is a td05 with a 20g wheel fitted, great performance from about 2900 rpm up. As for toe in, rear set up helps get back end out under braking and front end just great for turnning in, manybe your set up was for tarmac, which would not work at all, the coupe is fast and stable with this set up, have been running 195/60/15s on loose gravel and 205/65/15 and hard packed gravel. Say it once say it again, love wipping those other brands on race day ;D
John Stone
Quote from: groupb4ever on December 03, 2012, 09:44:32 PM
Gotta like what you're doing ;D
86 WR
04 A3
05 V50T5
