Author Topic: RS4 B5 MAF and DV replacement  (Read 984 times)
Offline waxer
Re: RS4 B5 MAF and DV replacement
« Reply #15 on: November 09, 2011, 05:30:49 PM »
Hey John/all, i have exactly the same issue with the stuttering for the first 5 mins when she starts.  seems to clear after that.  Did replacing the DV's help and the Maf too?  i had the fuel pump replaced not so long ago and Brodie pointed out the DV"s were stuffed.  just need to check its not a fuel supply issue from the new pump.  If it was the DV's what was the cost for install?
B5 RS4
Online RS ZWEI
  • formerly Golfboy666GTI
« Reply #16 on: November 09, 2011, 05:51:52 PM »
Replacing DV's is a DIY job (if you can reach them in a RS4?). The should cost you less than $100 each.
Offline waxer
« Reply #17 on: November 09, 2011, 06:23:41 PM »
Really? I have just got a quote back from Giltrap for 4-6 hrs labour!
B5 RS4
Online RS ZWEI
« Reply #18 on: November 09, 2011, 06:30:07 PM »
The should be in the same place as a B5 S4:
http://www.s4forum.com/forums/showthread.php?t=433
Offline waxer
« Reply #19 on: November 09, 2011, 06:44:52 PM »
Are these also know as turbo recoil valves?
B5 RS4
Offline HaNs
  • Put it in slowly and it wont crunch
« Reply #20 on: November 09, 2011, 08:21:46 PM »
Check for vac leaks also, had to fix vac leaks on a B5 RS4 the other week and it fixed up the idle.
98 A4 Avant, lowered, 19's (sold)
00 Polo manual (sold)
01 Golf Mk4 wagon, lowered, manual, BBS (sold)
88 Golf Mk2 (ABF and mk3 running gear)...project
87 Polo 86c, slammed (sold)
01 Polo GTI (gone)
01 Audi s3...bit much to list, money pit
99 B5 A4 1.8T quattro
« Reply #21 on: November 09, 2011, 09:11:31 PM »
I reckon it would only be a 30 min job for a professional. As stated many DIY swap (I haven't). Air recirculation or cutoff valves I think is the name Audi give them. I can recommend Brodie European if you want a professional to do it. If Giltraps quoted 4-6 hours I imagine they were thinking of something else - like EGT sensors.
2001 Audi RS4 with Viper Tuning Custom Remap, PSS9s, Hotchkis, JHM shifter & Supersprint exhaust
2001 Audi A4 1.8 Turbo Quattro Avant Le Mans
Offline weta.worker
« Reply #22 on: November 09, 2011, 10:24:26 PM »
My prob was a hose leak as well.  it got much worse (well the stuttering didn't, but I could start to hear the noise) and I had the part replaced (intercooler pipe) and all seems better (touch wood!)
Offline djrisk
  • Risky Bizness
  • No more radio show!
« Reply #23 on: November 10, 2011, 10:08:43 PM »
Go see Brodie european if you dont wanna do it yourself, it will take him half an hour tops
2000 Audi S4, BBS CH rims, K&N, 710N, Weitec Coilovers, Znoelli vented discs, Milltek catback + decat
Offline waxer
« Reply #24 on: November 12, 2011, 05:46:25 PM »
Thanks , will do
B5 RS4
Offline waxer
« Reply #25 on: December 10, 2011, 10:55:32 AM »
update -
Yep, both the DV's & MAF replaced and smooth as .
Brodie is the man
B5 RS4
« Reply #26 on: December 11, 2011, 01:24:56 PM »
update -
Brodie is the man
If you start getting intermittent types of flat or hesitating power, the exhaust sensors always go and often dont throu codes.
06 RS4 Avant Black
06 Touareg 3.0 V6 TDI
96 DC2 Integra R Targa Race Car
02 M3 race car project - On hold
Offline waxer
« Reply #27 on: January 19, 2012, 08:50:33 PM »
thats exactly what i am now feeling, nothing bad but just hesitating power at mid revs.  need fixing up promptly?
B5 RS4
