New Car for me, B7 RS4 Avant Black
Started by beeker, February 19, 2011, 04:42:07 PM
beeker
Quote from: nordschleife on August 13, 2012, 08:41:21 PM
Hi Noel,
Resurrecting an old topic here but I'm wondering if there have been any developments or if you have had your car on a dyno since?
I've driven 2 B7 RS4s in the last two weeks.  One a sedan that felt quick - similar to my M5 performance.  The other an Avant that felt lethargic.  Getting back into the Wife's Octavia vRS after driving the Avant felt like they had similar pace.  I'd say it was missing 100kw and was nowhere near M5 performance.
We'll you could say it had an additional carbon clean recently, as they replaced both manifolds under warranty!!
ie It chucked a solenoid error on the inlet flaps, and the factory said replace both entire manifolds.
It cetainly still has the 5500 kick.
13 TR86 race car
2018 Highlander
2017 Outback
nordschleife
Thanks.  Did you notice a change in performance?
VW Golf GTI - Track Car
VW Golf GTI - Road Car
VW Golf R32 - Sold
UKRSKiwi
I have staged an approach to mods for my RS and I can tell you that getting the carbon cleaned and any vacuum leaks sorted makes a huge difference.
The Avant sounds like a vacuum leak issue, basically goes okish but no kick or eagerness. Even with carbon build up the car should still give a kick.
Mine is perhaps an exception as I don't have any manifold flaps, power comes on smoother and top end has loads more toe if you get this done properly.
B7 RS4
MRC Stage 2 map
MRC Stage 2 Induction Manifold
Milltek Exhaust and 100 Cell DP's
ITG Panel Filter
Short Shifter
CAF
450ps proven.
beeker
Quote from: nordschleife on August 13, 2012, 08:59:10 PM
No, but it only had a carbon clean 9 months earlier. Butt dyno's arnt always accurate either!
I'm also consistent in giving it regular full revs (when fully warm). An unproven method, but makes sense to me.
13 TR86 race car
2018 Highlander
2017 Outback
Makes sense and must also be quite fun.
nordschleife
Quote from: UKRSKiwi on August 13, 2012, 09:39:11 PM
The more I think about this the more it makes sense.  The S button made no noticeable difference to the exhaust sound at idle in the Avant where in the sedan it was very noticeable - even the metallic sound of the flaps opening was quite obvious on the sedan but I don't recall hearing it on the Avant.  My understanding is that the exhaust flaps are operated via vacuum which also points to a vacuum leak.
Is there a common area that causes vacuum leaks on these?
VW Golf R32 - Sold
beeker
Quote from: nordschleife on August 17, 2012, 07:56:11 PM
Yes. I recall reading on rs246.com
13 TR86 race car
2018 Highlander
2017 Outback
UKRSKiwi
The first place to try is pipe work on the actuators for the exhaust flaps. Simply as they are the easiest to get to. Then it's down to your local Audi guru to trace it from there! Lots of small pipework to go through unfortunately.
The air box also has a flap in it that is vacuum controlled and this can sometimes seize. This will also affect performance however the exhaust flaps should still open.
Just for info,  the exhaust flaps are shut by a vacuum so when the car is turned off they should be open.
B7 RS4
MRC Stage 2 map
ITG Panel Filter
Short Shifter
CAF
450ps proven.
nordschleife
Thanks, I suspect they were open all the time - easy enough to check.  It was inside a warehouse when it started so it sounded loud due to that fact.  I don't recall hearing the exhaust flaps close as it sat idling.
It also had a couple of errors regarding insufficient flow on the secondary air injection system.  This could be vacuum related as well.
VW Golf R32 - Sold
Jeremy RS4
Quote from: beeker on April 25, 2011, 04:53:11 PM
When the carbon issue first arose, most thought it was a combination of oil recirculation from the crank case and valve overlap.
A few installed separate oil cans. Over time this has proven to not help, and the carbon issue appears to be a valve overlap related issue (with no fuel coming throu the inlet manifold to clean it).
There was a few guys looking at meth (I think it was meth) injection systems which would boost horsepower and also help clean the inlet manifold. Have heard no feedback since, but in principle it sounded interesting.
Fuel based additives may help a minor amount (and will help injectors), but as it doesn't travel through the inlet manifold, it doesn't clean it.
There has been a glimmer of hope with some new Aerosol based cleaners which you spray into the inlet manifold (ideally after the MAF) and many have reported noticeable increases in performance after use. I'm keen to try it myself as part of a preventative maintenance program, and are currently discussing this with Giltraps on the topic.
see: http://www.wynns.net/product_files/direct%20injection%20power%203%20(aerosol)%2023079.pdf
Beeker, this last paragraph is interesting. Any outcome from it?
Audi RS4 B7 2006
Black on Black
Custom Dyno Tune
JHM Intake Spacers and K & N
Deleted Cats
Hardwired Beltronics STiR (essential!)
beeker
Quote from: Jeremy RS4 on March 04, 2013, 09:29:30 PM
Never went there in the end. There is some interesting developments with some experimenting with water/meth injection into the inlet manifold. Not only does this keep it clean, but produce slightly more power.
http://forum.rs246.com/viewtopic.php?f=35&t=98750&p=552799&hilit=water+injection#p552799
Else, a 2 year manual scrub is required!
13 TR86 race car
2018 Highlander
2017 Outback
