Author Topic: What Suspension Mods To Do?  (Read 4741 times)
Offline .:R32
    • Things I like
« on: December 22, 2005, 12:40:59 am »
hey everyone I'm after a set of lowered springs for my 2000 a4 what do ya recommend i get? H&R, Kingsprings, MTM etc whats the lowest springs i can get and what would i be looking at paying for a set?
thanks very much for your help
Offline NasTnaS
  • Live and Learn.....
Re: What Suspension Mods To Do?
« Reply #1 on: December 22, 2005, 01:01:16 am »
go for H&R
...Nigel Aston
1971 Porsche 911T
2009 Renault Megane R26
« Reply #2 on: December 22, 2005, 06:39:24 am »
go for H&R
agree H&R lowering springs. If you wanna do it properly, do H&R Coilovers.
18 Disco5 HSE
Offline .:R32
    • Things I like
« Reply #3 on: December 23, 2005, 01:32:34 am »
just been looking at the h&r website and when using the Race springs (most drop in height) it says "performance aftermarket shocks or struts is highly recommended in this application"  :-\ would i be OK using the race springs with my Sachs shocks also can anyone shed some light about my suspension set up (Sachs)?
« Reply #4 on: December 23, 2005, 07:01:54 am »
I have SACH shocks on my 2001 A4 TQM Lemans. The lemans has the "quattro GmbH suspension kit" that was higher spec that the older 'Sport'.
If your only going 20>30mm lower than std with lowering springs, you're prob ok with springs alone. However, its always recommended you get a shock/spring combo, so you shocks are working in the correct range of operation. It depends on your budget and goal.
18 Disco5 HSE
Offline bsting
« Reply #5 on: December 23, 2005, 07:39:14 am »
For another option email  www.tmtuning.com
See what they can put together for you...btw ask for Robert or Damian (canadians who work there)
Offline i wana rs6
« Reply #6 on: December 23, 2005, 01:11:04 pm »
Where can you get sachs suspension systems?
tmtuning hasnt finished there website yet.
Offline .:R32
    • Things I like
« Reply #7 on: February 16, 2006, 11:51:57 am »
hey dose anyone know how much lower the audi a4 sports suspension kit (sach shock/spring) is compared to the standard spec a4, how much lower will a set of h&r race springs drop my height
thanks very much
Dicardo
« Reply #8 on: February 19, 2006, 08:18:12 pm »
Look up Eibach....I am fairly certain they support Audi. They provide the VAG sport suspension kit sold by VW of America. Spring/Shock matched combination. If you have the money my recommendation would be Eibach springs w/ Bilsteins.
hitmanGTI
« Reply #9 on: February 19, 2006, 08:25:40 pm »
Exactly what i am doing this week
Dicardo
« Reply #10 on: February 19, 2006, 09:46:44 pm »
Good on you Hitman. I didn't realize the beauty of that combination until AFTER I installed my Pro-kit >:(
Offline Turbo
  • was going to call myself bi-turbo, but i don't root blokes. sorry.
  • Twin snails - see my S-car go!
« Reply #11 on: February 19, 2006, 09:56:44 pm »
that's what i had in my A4, wicked setup. haven't compared it to H&R coilovers though.
what's the benefit of coilovers compared to a good spring and shock set up other than adjustability?
Offline Dubious
« Reply #12 on: February 19, 2006, 09:58:28 pm »
I'm looking at the H&R Cup Kit for my next car (whatever it may be  :D), heard nothing but good reviews
15 8V S3 APR Stage 1
Dicardo
« Reply #13 on: February 19, 2006, 11:27:57 pm »
For street driving, in my opinion, coilovers are the wrong application IF you are trying to use them for what they were intended. Coilovers provide the adjustability to balance the four corners of your car.
For street, a complimentary spring/shock combo is the way to go. IF you are looking to drop your car, then coilovers provide a cheaper solution than airbags. My 2 cents.
Offline NasTnaS
« Reply #14 on: February 20, 2006, 06:44:42 am »
but airbags are way cooler... for street purpose....
some say they even handle better [ Sarcasm Emoticon ]
...Nigel Aston
1971 Porsche 911T
hitmanGTI
« Reply #15 on: February 20, 2006, 07:00:24 am »
Im just waiting on the Rear Shocks to arrive.. ive already taken delivery of the front struts...  :o (they have big rods/shafts/pistons)
Offline Turbo
« Reply #16 on: February 20, 2006, 10:51:38 am »
a few reviews i've read about suspension set ups in audi quattros have all said to stiffen the rear springs to reduce oversteer.
would would this be easier to do with coilovers rather than guessing which springs would be right?
Dicardo
« Reply #17 on: February 20, 2006, 05:06:12 pm »
Is your A4 a quattro? If so, I could guess what the right answer is, but I'm not really sure. Your weight distribution would be different than what FWD A4's have.
In a FWD car, stiffening the rear end, typically reduces understeer (front from sliding). The stiffer the rear end, the sooner it will typically "break loose" and once the rear end starts coming around, your steering picks up....probably not the best explanation but you get the idea.
I have a rear sway set on the stiffest setting currently, which helps to "balance" the car. By reducing the available traction at the "lighter" rear end, the car behaves in a more balanced manner. With FWD if you lift your foot mid-corner you can typically get your rear end to slide as well. If you want good advise on suspension I would say write to Nuespeed in Camarillo, CA (via the web). I learned a lot from the guys there, just by poking my head in and asking questions.
The point I am making is suspension is a complicated thing, and simply me telling you what to do over the net, won't necessarily address the issue you are trying to correct. Get to the source and see what they tell you about suspension behaviour in general, before making the next decision re: spring/shock or coilover.
Offline Turbo
« Reply #18 on: February 20, 2006, 05:41:53 pm »
yeah it was a quattro, i should mention it also had a 32mm sway bar which would also contribute to its keener steering.
that set up was really good as far as i was concerned, but i've read a few things about H&R coilovers (most of it on here) that suggest they're better.
they're more expensive, certainly, but if i don't need adjustability, then surely i don't need coilovers.
this is all academic at this stage, cos i don't think i'll get around to doing anything with my S4's suspension or handling for a while. it's not as good as my A4's was, but not bad by any stretch of the imagination. and lowering it isn't an option unless i move house (i guess that's one case why coilovers would be better than springs)
Dicardo
« Reply #19 on: February 20, 2006, 06:46:01 pm »
...but if i don't need adjustability, then surely i don't need coilovers.
That is certainly my opinion. Buying coilovers for street use, for any reason other than adjusting the ride height appearance, is using the technology incorrectly. Look, coilovers are fantastic, but for the premium you pay, unless you have your car balanced, it's like buying 285's for a car with 200hp. Yeah they work, but do you need it? Oh, and I don't always take my own advice either, so if you see my car, don't ask silly questions like "Do you really need that"...it would be missing the point :)
