Author Topic: Question about my auto transmission  (Read 1463 times)
Wolf_
« on: July 13, 2011, 09:26:54 pm »
Hi
I've noticed it for the third time now that sometimes the transmission will 'disengage' or slip near the beginning of a drive. Tonight when i was pulling out of my driveway as i came to a stop, then attempted to pull out, there was not response when i pressed the accelerator. After giving it a bit more juice the gear seems to snatch back into life. It kind of feels like when the car is in neutral. Once, the car started to roll back until i gave it a bit more juice. Should I be worried about this?
Seems like it could be a gear selection problem or something. I've never had this problem other than in the beginning of a journey.
Cheers guys.
Offline Andy_007
Re: Question about my auto transmission
« Reply #1 on: July 13, 2011, 10:01:58 pm »
I had a problem like this but when the trans was warm.It happened 2 times within a couple days, It was pretty worrying since it has 235k km on it. Had the fluid and filter changed. I have put 3,500km on the car since, hasn't done it again.
2007 Audii A4 Quattro 3.0TDI
« Reply #2 on: July 13, 2011, 10:23:26 pm »
Yep sounds like low fluid to me, get it serviced.
Wolf_
« Reply #3 on: July 13, 2011, 10:36:43 pm »
Do you know a good place around central auckland for this? How much we looking at?
« Reply #4 on: July 13, 2011, 10:48:13 pm »
The only place to go is auckland automatics, around $250?
These boxes should be serviced every 20-30,000km and most of them have never been done!
Offline Andy_007
« Reply #5 on: July 13, 2011, 10:41:29 pm »
It cost me just over $100 for 4 liters of ATF, filter and labor
« Reply #6 on: July 13, 2011, 11:07:35 pm »
I'd wonder what sort of job that was considering a decent quality trans kit costs $60-80 without fluid or labour.......
NextLevelDubClub
« Reply #7 on: July 26, 2011, 06:11:46 pm »
could be as simple as fluid and filter. Although you may find that the o-rings in the transmission are becoming loose or breaking down. I had a problem exactly as you described, and when they went to do a filter change, they found disintegrated o-rings in the tranny sump. Very expensive job. Fingers crossed for you that its a quick fix
Wolf_
« Reply #8 on: July 28, 2011, 12:38:43 am »
Really unsure about what it is.. Has only happened once more since my last post. I had a full fluids service back at the end of May. Might be seeing the garage later tomorrow/today, you suggest i mention this?
Wolf_
« Reply #9 on: July 28, 2011, 12:43:11 am »
Actually i do have a slight oil leak, like maybe 1 droplet every 2 nights? hopefully unrelated   :o
« Reply #10 on: July 28, 2011, 07:06:30 pm »
Mk3 autos are crap and the solenoids give plenty of trouble.
 The correct fluid and a filter and labor is a $250 job for sure how Andy got a it done for a hundy is beyond me.
Offline johnp
« Reply #11 on: August 01, 2011, 09:06:27 am »
Just do what Vert suggested. It will then be serviced properly.
« Reply #12 on: August 01, 2011, 09:19:25 am »
 You mean serviced at all :P If it was serviced properly it would have been done many times already.
Offline johnp
« Reply #13 on: August 01, 2011, 10:21:08 am »
foxman
« Reply #14 on: August 02, 2011, 03:32:26 pm »
WANTED VR6 TRANSMISSION FOR 96 GOLF CODE CLB .thxs DAVID
Offline elliott2705
« Reply #15 on: August 02, 2011, 03:33:43 pm »
Best of luck mate, theres a long queue. And they are practically impossible to find.  :-\
