Best air filter for A4 1.8qt
Started by dj thumpa, February 03, 2006, 09:51:13 AM
dj thumpa
Gidday,
Pod discussion in another topic got my wondering whats the best bet for a 1.8qt?
Is it possible to fit a Pod or do you have dramas with air flow censors etc?
This mofo: http://www.knfilters.com/search/product.aspx?Prod=RC-5051AS looks Badass!
Any advice would be helpful,
Cheers, Warwick
cao
Won't add power will only increase the amount of noise you hear from the DV
I think particularly Olly ones have had issues but lightly oiled ones will be fine
dj thumpa
It seems strange  :-\, I've alway though that a freer flowing filter would help ('slong as its cold air) increase power? Are K&N classed as light or heavily oiled filters?
timmay
Yip, POD filters should add a bit more power but of course it depends on the application. Its the air filter panel (OEM replacement ones) that don't add much if any power.
2001 Porsche Boxster S: Meridian Silver| De-Ambered | De-Snorkled Intake
2003 VW Golf R32 | 2009 BMW Z4 sDrive35i | 2007 BMW 130i SE MSport | 1999 Honda S2000 | 2003 Mazda RX8 Type-S | 2000 VW Golf GTi | 1998 Mazda MX5 RS
dj thumpa
Struth, so potentially the above mentioned K&N might be worth a try.
What kinda problems do pods impose with the censors etc?
Period_Correct_
the motronic system and its sensors are advanced... very advanced, those "airboxes" are specially designed for your vehicle.... has alot to do woth mass air flow rate and pressure...
your motronic ECU will adjust to suit the newer "pod", probably wont be for the better...
i wouldn't change that, just get a better panel air filter...
timmay
Yea might be worth a try. That one looks like a universal fit one though and you probably better off going with a proper K&N Typhoon kit for a 1.8T or something like that.
Dunno about the sensors, but just watch that you don't get water sucking into it. The K&N POD filter kits for a MKIV 1.8T Golf pipe down to behind the front passengers side lower grills. Just don't go driving through a flood or anything  :P
dj thumpa
just had another look under the bonnet in my lunch break. The ducting goes all up and around a fairly tight vicinity! May be a bit tricky fitting anything after market  ???
Quoteyour motronic ECU will adjust to suit the newer "pod", probably wont be for the better...
Surely this must be the same with all modern cars that people tinker with, usually a free-flo filter being first on the agenda?
Period_Correct_
I read on audi forums that pod filters are not good unless u remap and have a induction kit and lada dadi...
go panel filter....
dj thumpa
Aiight, so I take it that most people here (on vask) with 1.8t engines have stuck with their standard box and maybe an up-rated panel filter yeah?   8)
timmay
Quote from: dj thumpa on February 03, 2006, 03:10:37 PM
Yip, I have....dunno about everyone else.
timmay
Oh yea...although u won't get any noticeable power gains, I did notice that she did rev a bit free-er...plus you don't need to replace them. Just clean and re-oil.
hitmanGTI
Quote from: dj thumpa on February 03, 2006, 09:51:13 AM
Gidday,
Cheers, Warwick
It will increase power marginally if you install it correctly and follow up with the rest of the intake with silicone hoses or stainless piping replacing the small bore induction piping..
If you buy that i would then suggest you find some method of plumming the inlet of that to one of your lower front air dams so it has its own food source...
I have had a panel filter installed my self as the standard airbox is fine.. i removed that randome cone/trumpet inside as i havent the faintest clue what it does... how ever i plummed the inlet of my airbox to my lower front left airdam the car breathes a heck of a lot better. and apparently has a nice induction noise
beeker
The best is a K&N std airbox filter. DONT INSTALL A POD !! You'll only sux hot air.
13 TR86 race car
2018 Highlander
2017 Outback
Turbo
Quote from: beeker on February 03, 2006, 06:35:25 PM
just stick it in a bucket and fill it with ice, you'll be sweet.
hitmanGTI
avoid installing pod filters next to friends that talk alot.. the engine will run at a higher risk of over heating from the inside out
hitmanGTI
Quote from: NasTnaS on February 03, 2006, 12:23:52 PM
Motronic this... to advanced for their own good.. what a waste of damning time
