Thanks!Just spotted a new one on eBay for about $110 NZD delivered so will probably run with a new one for reliability. Might still go visit pick apart though.
Good to get a new one. The old boot trick can save the day Glad that worked. make sure you do the filter as well as you can burn out a new pump if the filter is partially blocked. I do have plenty of 200 and 100 pumps if you want one tho i wish I had said that before.....
Good advice guys. Thanks.
Andy mine's an Auto quattro with 256,000 kms and going strong. It does have an aftermarket external transmission cooler (radiator cooler is now bypassed) and I replaced the transmission filters and flushed the fluid when I first got it a few years ago. The original fluid smelled quite burnt so I think it was worthwhile.
