yep, standard at 2 bar max
I had a look through a scanned version I have here. Normal range is 50 to 120 deg celsius or 122 to 248 deg fahrenheit. I was a bit concerned when it was sitting at 200 fahrenheit yesterday, but according to these numbers it's within limits
You should see around 1.7 bar and only two sectors lit-up on the kinda flakey quattro boost gauge. If it goes to 3sectors you could be heading towards 2 bar.
The 1 bar displayed at mid point is atmospheric pressure (1 bar) - the boost itself is .7 or in good old imperial around 10psi.
Upping the boost without attention to getting the fueling spot-on is risky as running lean and pinking will not be apparent at 5k revs and beyond
I have heard of cars running as high as 14psi on K jet but I'm not game....
When I'm running the car on the track water temp may only shift one notch up from normal. Not sure what that indicates in fahrenheit but as you've noted yours is within the normal range
