Hi
I have been working on a T4 non turbo 2.4 I5 diesel van.
It was overheating in traffic and pressurizing the cooling system so the head came off.
New valve guides on the exhausts and new seals and head gasket and its all back together.
Had the injectors serviced as well.
Timing is pretty easy, TDC for crank, cam has a slot at the back that you put a flat bit of metal into that aligns straight with the head top. And the fuel pump has a notch.
I aligned everything and have turned by hand several times and everything lines up bang on.
The van starts but runs very rough and blows huge clouds of smoke. Stalls as soon as I get off the gas.
There are no filter hand pumps on this car
So I am to believe that its just bleeding the air out............but its taking to long and I'm worried.
Has anyone else done a VW diesel and had this experience or know any tricks?
I will try to crack the injector hoses as my flatmate cranks it, but would be good to hear of any other experience.
Thanks.
