Digifant Idle problem...
Started by rambo_005, January 24, 2005, 10:59:01 PM
rambo_005
Hi all,
My RV Digifant Golf has just started to play up at idle.
When you start the car it idles fine, after you have touched the throttle it idles at 2krpm.
What is it most likely to be?
robh
does the digifant have a Bosch ISV?  if so they do wear out and you get similar issues to what you have or maybe a generic vacuum air leak?
rambo_005
I had a look over the vacuum lines, fairly sure its not them. I'll take a better look tomorrow. Not sure about the Idle stabiliser valve, have only recently started working on my engine since the best VW mechanic I thought possible had a stroke :( (The rest are ripping off bastards thats don't even know what theyre doing!)
robh
you can sometimes see scoring marks inside the ISV once you've taken it off, this can mean it's worn out....
dubstar
wilco
you gotta be joking dubstar - digi is way ahead of k-jet!  This os from someone who has more k-jet cars that I need.
Clean all the gunk out of the ISV and try again. How many km's has the engine done?
dubstar
Quote from: wilco on January 25, 2005, 11:39:36 AM
you gotta be joking dubstar - digi is way ahead of k-jet!?
Yes I was
rambo_005
Quote from: wilco on January 25, 2005, 11:39:36 AMHow many km's has the engine done?
It has done 175,000km now, this is the first problem that hasn't had an obvious fix for me.
rambo_005
It has a VDO ISV. I took it off and it appeared to be gunky on the inside, squirted contact cleaner in it and got it all out. Now it idles at 1200rpm, an improvement but not fixed. I'll have to dig out the spare ISV from an 85,000km car I wrecked a while back and try that out.
use partmaster brake clean :) dont worry about the cancer it will give you  :P
rambo_005
Quote from: orggti on January 25, 2005, 08:59:01 PMuse partmaster brake clean :) dont worry about the cancer it will give you :P
cancer?  ;D
Where do I get that from, Repco?
Period_Correct_
Quote from: rambo_005 on January 25, 2005, 09:07:45 PM
cancer?? ;D
PartMaster..... 8)
its got tons of touoline in it works well but gives you cancer for sure if you dont be very carfull not to breath it in
rambo_005
Quote from: NasTnaS on January 26, 2005, 04:49:17 AM
PartMaster..... 8)
Cheers orggti, will see what I can find.
Never heard of PartMaster btw :S
rambo_005
Found a vacuum leak on a small plastic cap on the side of the intake manifold, i covered it with a screw driver and the idle dropped.
I also changed the ISV with the cleaned out, lower km one and it idles fine. Need to properly fix that cap tho (tape and cable ties ATM!)
I might try the old ISV again and see if it still goes ok, so I can count that out.
Cheers for the help guys!
those goddam air leaks on golfs and audis
bsting
Yes, & Vag stick em in hard to get at places - hands come out bloodyed.
:P
