Big brakes
Started by 00quattro00, February 27, 2012, 07:11:45 PM
00quattro00
What options for big brakes is there that will work with 4x100 hubs? Is 280mm rado the biggest that will work?
rambo_005
For factory bolt on fit, 280mm G60 is the biggest 4x100 set up.
You need Passat GT or 1990+ GTI 16V hubs and G60 calipers/carriers/discs.
I have some hubs, calipers and carriers for sale.
00quattro00
Will 280mm be big enough for a track car? Those 2pot calipers weigh a ton too
MK3 GLI carriers are exactly the same also.
00quattro00
I had mk3 gli brakes on my old mk2 gti, they were good for an 8v on the road, but I dont think they will pull up a 1.8t on the track
Correct, they wont.
The Vento has fancy 4 pots with 312's and are too small.
00quattro00
I do have a set of porsche calipers (same as rs2) and rs2 caliper brackets that I was going to use on my 90 quattro, would they work as the caliper bolt spacing is the same
00quattro00
Will have to dig them out and have a test fit, hopefuly the offset is the same or ill have to machine another pair of brackets
