Author Topic: '89 100 ee WOF failure: "remedy play in LFrnt wheel bearing"  (Read 1658 times)
1oldAudi
« on: March 02, 2006, 12:07:06 pm »
But i bet you can't... what hassles am i up for and does it mean new bearing time? Maybe a little bit about the procedure i'll be facing would be appreciated.... Thanks
1oldAudi
Re: '89 100 ee WOF failure: "remedy play in LFrnt wheel bearing"
« Reply #1 on: March 04, 2006, 02:31:32 pm »
No probs now all sorted. ** Might ** see you at Ellerslie Carsales tommorrow.
« Reply #2 on: March 04, 2006, 04:05:26 pm »
nice one did you just have to tighten the nut or did you replace it?
1oldAudi
« Reply #3 on: April 03, 2006, 12:18:48 am »
Yes, it was an easy fix when i found nothing wrong with the front bearings but tightened the nuts on the rears when i found they were quite obviously sloppy. Returned the Testing Station and the testers spent extended time on it re-checking things and happially past it. I didn't question the frnt comment on the check sheet that they'd previously failed on.
« Reply #4 on: April 03, 2006, 01:45:30 pm »
Ahhh so they didnt fail your floppy rear wheel bearings, but they did fail your perfectly good front wheel bearing that they then passed later ::) Dont you love WOF inspectors :police:
