Author Topic: Q: Changing Rear Discs on MK3 5 Stud....  (Read 636 times)
Offline ziptie.nz
« on: June 01, 2012, 01:59:00 pm »
The Question pertains to the Changing of the Rear disc on a MK3 GTI/VR6 Rear Beam...
The New Discs don't appear to have the ABS Speed Rings installed on them?
Is there a ABS Specific Disc or does the Speed ring get removed from the old disk and pressed on to the new disc?
MK2 GTI 16v, MK2 TDI - Rollin' Coal, Audi V8 Quattro, Audi A3 Sportback 2.0 TDI
Re: Q: Changing Rear Discs on MK3 5 Stud....
« Reply #1 on: June 01, 2012, 02:42:34 pm »
Gently lever it off and re install on the new one....
Offline coons
  • Sam
« Reply #2 on: June 01, 2012, 05:13:49 pm »
Before you start greasing up bearings, make sure the speed sensor ring actually fits over the little hub on the disc.
I built up mine with new bearings and packed it all with grease, then when I went to put the ring on, somehow they wouldn't fit over the disc.... not sure if it was a bad batch or a different part. Either way I had to clean the stupid thing out and take it back to the shop to be replaced. Second batch fitted fine
Mk3 Golf 1.8T
Honda GB600 Cafe Racer
« Reply #3 on: June 01, 2012, 06:40:10 pm »
 Nice info 8)
