1.8t mk2 jetta
Started by 00quattro00, July 26, 2012, 09:50:09 PM
00quattro00
Going to be making a loom for a 1.8t to plug into a mk2 fuse box, anyone want one while im at it? This is so you can run a standard ecu with the immo off (only costs $160 to have this done) and standard mk2 dash and instruments
RevHappy
CURRENT: Mk2 Golf - 1.8t, Coil overs, Passat leather, 16x8, Daily Driven
GONE: Mk2 Jetta - Big Bumpers, Big Windows, Lowered, 15X6 Alloys, and MK1 Suzuki Cultus Gti G13b rally cams, bilstein shocks and springs, momo 14X7 alloys
flying
00quattro00
Quote from: flying on July 27, 2012, 09:12:17 AM
Can you do mk3 as well?
I could but I dont own a mk3 and havent worked on them much
JC
Is this for your jetta? Glad to see it made it down ok and is looking good!
Hes saying it cost $160 to delete the immo not to build you a loom.
Plus he says all sorts of things but rarely does them, always finds some new project.
Young people.
I'm not being mean I do the same myself :-[
00quattro00
ECU is on its way back, Have got my wiring sorted, just need to fit a fuel pump as it was a carby and finish of the intercooler plumbing
Good lad. Is that why you wanted my mk3 tanks for the fuel pump etc?
00quattro00
Yea, Ill just use an audi kjet pump, idk why vw put the pump in a crapty plastic housing
00quattro00
Intercooler piping dropped off to be welded so will only have silicon joiners on the turbo, intercooler and throttle body. got nice black ones not that tacky blue, will also paint the intercooler and piping black
00quattro00
Got the audi kjet pump plumbed up and mounted, man it shifts some fuel, pumped 30l thru it and no leaks,
Ecu arrived today so I just need to wire up the pump and see how good my wiring is :P
choppy16v
rad baz good luck with wiring.i'm backing you to finish this one off!
00quattro00
yay have spark and fuel, now I can wrap the loom and start putting it back together
00quattro00
Had a good afternoon, removed the engine and box, water blasted the engine bay, finished wrapping the loom and routed and cable tied it up, refitted engine and plugged it back in, have a bunch of little things that need finishing
DV and N75 plumbing
Mount header tank
Mount air filter
Brake booster vacuum line
Alternator wire
Mount slim fan
Make an exhaust and its good to go
Youll have to take us for a run in it once its going.
00quattro00
nacnud
Whatcha Think?
Flickr
1991 Jetta ABF
CGK
00quattro00
Didnt get much done today, couldnt stop fidling with bits for 20vt,
Took some pics
