1.8t mk2 jetta
Started by 00quattro00, July 26, 2012, 09:50:09 PM
watercooled
That sucks was it wrongly supplied?
2002 T4 transporter 2.5 TDI.
00quattro00
Quote from: watercooled on September 23, 2012, 08:23:24 PM
No just me being lazy and a bit hopeful that one for a mk4 would fit a mk2, have made my own out of 2.5" mild
00quattro00
#62
Will be fitting 288mm vr6 brakes this weekend, going to keep the mk2 subframe an arms so it wont be wide track, just need to sort out some front shocks as my bilsteins have gone mushy and then it can be certified
00quattro00
It has a bilstein suspension kit in it and the front shocks need rebuilding/replacing, replace them or get a set of coilovers? A pair of bilsteins will cost me $585 from demon-tweeks or a set of kw v1 for $1030, not to sure on the quality of the cheap coilovers tho and the bilstein kit drove realy nicely befor the fronts went mushy
You can get the billies rebuilt for about $160 each. Do that.
00quattro00
Autoalign in Carbine road.
Not sure if thats how its spelt :-[
00quattro00
Recoded the ecu to manual as it was orig from an auto mk4, now idles properly and doesnt hold the revs when I let off, just need to finish fitiing the vr6 running gear, hopefuly do that on christmas day/boxing day, I dont get many holidays this year :'(
00quattro00
Bit of an update, finaly got around to fitting the vr6 running gear and getting it all back together, just need to make an exhaust and finish of a few minor things.
Needs a good clean from sitting in the shed for the last 6mths
Looks smart on the Mk3 GTI rims.
00quattro00
Quote from: RS ZWEI on April 10, 2013, 05:34:42 PM
Yea im loving them, not bad for a $1.50 score on trademe
Bit cleaner now
SOFTLAD
Quote from: 00quattro00 on April 10, 2013, 05:37:06 PM
Result
They look good on the jetta, OEM but not quite
Period_Correct_
Jettas look so good....
00quattro00
Mines a getta at the moment
Those wheels do look good.
00quattro00
Exhaust is done, quite but sounds ok for a 4cyl.
Have ordered a new 22mm master cyl from qualitat so when that arrives in the morning ill fit it give it a bleed and then its wof time
nordschleife
Quote from: 00quattro00 on April 11, 2013, 06:38:13 PM
Keen to have a look if you are around this weekend?
VW Golf GTI - Track Car
VW Golf GTI - Road Car
VW Golf R32 - Sold
00quattro00
Yea should be, sunday would probably be best
00quattro00
Just been for an hour long drive, went well. I have an 8v gti box on it atm and with the short ratios it gets along nicely, pulls away nicely from 50km in 5th
