B5 S4 tuning
Started by werc1, July 26, 2012, 10:14:10 PM
werc1
Just picked up a stock B5 S4. Looking for some go-fast goodies, any one on here have recommendations from personal experience.
B5 S4 Avant (Imola), 1968 Camaro 350, 1972 Chevelle 396, LR Defender
00quattro00
034motorsports big single turbo kit ;)
werc1
Yes, their kit is ridiculous.  Would be nice to get the GT25R 550hp.  Anyone have one done up here in NZ?
beeker
Look on www.rs246.com for proven bits. Mostly high glow exhuast and cats i suspect. You're always gonna struggle with NA.
13 TR86 race car
2018 Highlander
2017 Outback
Quote from: beeker on July 27, 2012, 06:34:19 AM
NA? Its a B5 S4.
le mans
What's your bugget? The sky is the limit. Most of the UK B5 enthusiasts are on audisrs.com these days and so that is a good site to trawl around on for ideas.
Turbo
you sir, have impeccable taste.  8)
You'll find the B5 much more receptive to modding than your B6.
year/kms/pics/sedan or avant?
as le mans says, your budget is the deciding factor... and what you want to use it for. (daily driver/trackdays/project car)
if i were in your shoes (and i was) i would make sure to upgrade the suspension and brakes. After stage one you will only go faster in a straight line, you will still be limited by nose heavy understeer in corners.
read my sig for the parts i've done in that respect. positive transformation of the handling.
as for power, so many options.
if you plan to go >stage 2 do all your physical mods before chipping/remap so the program can take what you've done into account (rather than having to do it twice, pre and post)
realistically you'll get to about 350hp on the stock Ko3's while maintaining reliability.
inspiration of why to go bigger... vid of 3rd gear pull between 322 and 550hp B5's:
http://www.youtube.com/watch?v=MrK4AFYRz30
shopping list:
exhaust + down pipes with decat
manifold
710n diverter valves or better
larger turbos (how big depends on how much lag you can handle if used as a daily)
intercoolers (as above)
uprated fuel injectors and pump
probably MAF and intake (cold box - engine bay too cramped and hot for exposed cone, consider repositioning lower)
bigger turbo inlet and Y-pipe
silicone hoses
engine mounts
clutch/flywheel
various nuts, bolts, gaskets, sensors and rings
and obviously, remap.
and a lot of money.
le mans
Here's an example of what you can do if you have unlimited funds. It's an RS4 but you get the idea (pic heavy): http://forum.rs246.com/viewtopic.php?f=1&t=93350
Turbo
And if you don't mind cutting a few holes in the body work, 1000+hp
http://www.audiworld.com/news/06/audi-9-seconds-in-poland1/
Filx
VR6+T is the only way to go. Anything else is just tinkering around the edges.  >:D
M
Quote from: Filx on July 27, 2012, 01:02:30 PM
>:D >:D
beeker
13 TR86 race car
2018 Highlander
2017 Outback
werc1
Thanks all - for budget will depend on what I finally decide but there are 2 options for me.  Silly horsepower (450+) or basic (350).
For the silly horsepower, I'd be comfortable w/ 450+ but looking to try and stay under $7k (have had a look around and a few contacts in the US may be able to source me cheap products).
Basic is ecu upgrade, exhaust and a few other goodies. (few grand)
00quattro00
Pretty sure he doesnt want an anchor  ;D If your going to change engines there is only two options, v8tt or a 20vt 5cyl
M
I have genuine standard RS4 intercoolers, downpipes and standard RS4 turbos.
Add those and appropriate injectors etc an you can see 450bhp.
CDL
Would be very interested to see this thread progress :)
Oh how I wish I had the time and money to make mine more of a go machine!
werc1
Quote from: M on July 27, 2012, 07:01:19 PM
Can you share with me pricing and dealer?  I'm looking at both things locally (NZ) and importing from the US.
tonyoh
The S4 can be developed to produced great HP I am sure, but the brakes and suspension would also probably need a helping hand. Fundamentally they start at a similar place.
But if you were after 400-450HP, which would be the cheaper option - buy an S4 and do a reasonably extensive upgrade, or buy an RS4 and chip it (only for a few HP too)? 265hp to 400 would be much harder and more expensive than 380 to 400hp...
The RS4 would start to look relatively cheap I would have thought, but the time you replace turbos, injectors, remap, and suspension/brake upgrades... And then there is the looks - the RS4 is pretty good looking (IMHO anyway).
rs4 wagon (B5)
CBRT
Quote from: werc1 on July 28, 2012, 02:54:59 PM
he meant he has them in the shed at home, that he removed to upgrade i think
2013 MK7 GTI
2003 Audi RS6 Avant
