Author Topic: B7 Carbon Clean  (Read 19166 times)
Offline ziptie.nz
Re: B7 Carbon Clean
« Reply #20 on: August 29, 2012, 07:41:00 am »
Would probably be worth while having a 9th injector just after the Throttle Butter Fly to help clean that kaka off...
thats horrible..
will probably explain why my MPS got a bit slower (same crappy direct injection technology with polluted breathing system)
Most the Guys in the Mazda scenes were running These Catch Can Systems.. (with some what complex plumbing involved) but the amount of s**t they could drain out of it just after a week was unreal..
MK2 GTI 16v, MK2 TDI - Rollin' Coal, Audi V8 Quattro, Audi 100 2.2 ee
Offline BB
Re: B7 Carbon Clean
« Reply #21 on: August 29, 2012, 08:44:09 am »
Blow back :(
 Its caused by crank case ventilation or "blow by".
 As for it not being an issue......well clearly it is, as noted by your immense improvement in power.
 There is a can of stuff available at Partmaster specially for this, get some and spray it in periodically to stop it getting so bad again.
Offline UKRSKiwi
B7 Carbon Clean
« Reply #22 on: August 29, 2012, 08:45:01 am »
Honestly, this would put me off B7 RS4 ownership.
It shouldn't. Take it as a maintenance item, once every 50k km just expect to clean it. Its a small price to pay to maintain 400 odd horses in such a good chassis. It is still a very high performance car and it comes with associated maintenance baggage, but the end result is worth it.
What will be interesting is if we see RS5 and B8 RS4 engines just as bad in 2 or 3 years. Anyone know if Audi have at least attempted to address the issue??
« Last Edit: August 29, 2012, 08:46:44 am by UKRSKiwi »
B7 RS4
MRC Stage 2 map
MRC Stage 2 Induction Manifold
Milltek Exhaust and 100 Cell DP's
ITG Panel Filter
Short Shifter
CAF
450ps proven.
Offline UKRSKiwi
B7 Carbon Clean
« Reply #23 on: August 29, 2012, 08:45:56 am »
Blow back :(
What's the product BB?
B7 RS4
MRC Stage 2 map
ITG Panel Filter
Short Shifter
CAF
450ps proven.
Offline BGS30
Re: B7 Carbon Clean
« Reply #24 on: August 29, 2012, 09:25:32 am »
As I understand it, this only affects FSI engines.  Is this correct?
Offline BB
Re: B7 Carbon Clean
« Reply #25 on: August 29, 2012, 10:04:27 am »
Ill get the name when I go to Partmaster next.
 Yes it affects FSI the most. All engines get some carbon build up but the FSI seem to do this.
Offline KiwiC4S
Re: B7 Carbon Clean
« Reply #26 on: August 29, 2012, 10:26:40 am »
Including turbocharged FSI's?
'06 997 Carrera 4S
Offline 00quattro00
Re: B7 Carbon Clean
« Reply #27 on: August 29, 2012, 11:25:33 am »
It happens to 99% of direct injected engines, you would think that they would have came up with s fix by now
Albacol
Re: B7 Carbon Clean
« Reply #28 on: August 29, 2012, 12:19:11 pm »
Based on my post-cleanp drive of the murfsters mine is going under the knife in 2 weeks time as it is flat and always has been. I've done myriad of coil packs under warranty, plugs twice etc and this is the only reasonably explanation. The person who is doing it said they had done a FSi Golf last week that was utterly clogged so it's not just this engine that suffers. I'll get photos taken and a before and after written up.
Re: B7 Carbon Clean
« Reply #29 on: August 29, 2012, 12:28:37 pm »
hmmm.. my lowly golf feels flat too and sounding like a diesel. fsi engine and all..
MK6 GTI
B7 RS4
Offline BB
Re: B7 Carbon Clean
« Reply #30 on: August 29, 2012, 01:42:58 pm »
FSI engines do sound like diesels. The burn is so lean its like a diesel clack.
 Id say one of the problems is the stupidly long service intervals that everybody seems to think is fine....fine for who? The manufacturers as its a selling point and the cars wear out faster when out of warrantee.
Offline Stickman
  • Audi & Motorcycle NUTTER
Re: B7 Carbon Clean
« Reply #31 on: August 29, 2012, 04:35:58 pm »
According to Audi the problem never/doesn't exist :o. Or so it would appear from responses different people have had on various forums.
I like fast toys.
2017 Audi RS6 Performance
2007 Audi RS4
Offline BB
Re: B7 Carbon Clean
« Reply #32 on: August 29, 2012, 04:44:24 pm »
At what sort of mileage was your car?
 I'm thinking ok for a RS4 owners may show enough interest in their beasts such as the person in this thread but how many other owners of FSI motors want to spend or pay for 14 hours to clean their motors out :P
 The lady I know with a FSI golf sure won't.
 It will end up being hard to sell an old gunked up one.
Re: B7 Carbon Clean
« Reply #33 on: August 29, 2012, 05:22:35 pm »
All FSI's are the same. Techncially the very very latest designs have reduced effect here.
It shouldnt turn you off a RS4. If its $1k every 3 years, build that into your budget.
Offline Turbo
  • was going to call myself bi-turbo, but i don't root blokes. sorry.
  • Twin snails - see my S-car go!
Re: B7 Carbon Clean
« Reply #34 on: August 29, 2012, 05:42:34 pm »
rather spend it on hookers and blow.
Re: B7 Carbon Clean
« Reply #35 on: August 29, 2012, 05:59:42 pm »
Gold.
Re: B7 Carbon Clean
« Reply #36 on: August 29, 2012, 06:40:36 pm »
haha, that wont go far!
Offline lunchie
Re: B7 Carbon Clean
« Reply #37 on: September 04, 2012, 03:37:24 pm »
how often does audi suggest you change the oil on the b7 RS4 and how often would you need to clean this crap off? is it doable yourself? I have always wanted an RS4 but when I did some reading on this it totally put me off as I wasnt sure if it was going to be an every 5,000kms job or what>?
Offline UKRSKiwi
B7 Carbon Clean
« Reply #38 on: September 04, 2012, 04:07:48 pm »
Every two years on long life oil,(fine if not often hammering it but once a year or 10k's if you do)
I carbon cleaned mine at 60k km and will do it again at 120k,  mine was only down around 10ps IIRC due to carbon. It's an issue that just needs to be accepted it is not a reason not to get one unless owning one is stretching you financially. It's a high performance car with high performance costs.
B7 RS4
MRC Stage 2 map
ITG Panel Filter
Short Shifter
CAF
450ps proven.
Re: B7 Carbon Clean
« Reply #39 on: September 04, 2012, 09:22:22 pm »
The thing I hate about is that as soon as you have them cleaned they start carboning up again, which equals a decline in BHP. Its BS! And its not about being financially stretched, its a PITA. What if the issue was that B7 RS4 went through front tyres every 5,000kms? Would you just accepted it as part of owning one?
When B5 RS4 wheels were bending owners didnt accept that and got the wheels replaced by Audi.
Ill never fear lining my RS2 up against a B7 RS4, more than likely the B7 RS4 will be carboned up and the 17 year old RS2 will kick its butt.
