The reason for chipping is that the flow of the 16v way exceeds any thing you can do to a 8v head period,a good set-up 8v chip will help and you can adjust the stock diji afm to help or go for a 2e afm(worked for me)
Sorry BB but the Saab dizzy won't cut the mustard,as mentioned there are ignition curve problems ,the loom and wiring is up to you and no differant to what i've just done,like anything'' if you have done it its easy ''.
Make a wise decision regarding ce 1 and ce2 loom for your car ,getting a ce1 to work on diji 2 is less work than a loom change,but will make it easier if you don't have much wiring experience.
Basically (sounds easy
) presuming your car is k-jet?,if you retain ce1 loom you need to repower the fuel pump,use the warm up regulator feed for that,you need to wire in a basic relay to power your ecu this feeds off the "key on" side of the fuseboard,earth to body,relay feed output 87 to wiring under the scuttle near the heater inlet.
There are issues with other stuff like temp sensor repositioning and extensions to the stock diji ecu loom ,don't be put off,besides there too many digi haters on here
