2006 Jetta TDI wont't start- help
Started by 6evil9, September 25, 2012, 08:22:19 AM
6evil9
Hi guys
i have a huge problem - all sudden my Jetta won't start.
It previously had some troubles with starting if parked uphill over night (had to spin it for 5-10 seconds), but this time it is just dead.
I have recharged battery (it is not new, but still can turn the starter for a minute or two) but still no signs of combustion.
engine is spinning but no combustion sound.
It also was a bit low on diesel so i added 10 more liters.
Ok i pulled the car out and now it is facing down hill, recharged battery but still same thing.
Any ideas? how can i check if engine gets fuel?
I tried to scan it with a scanner (cheap bought on ebay) but it returned nothing and could not scan diesel pump :s
Thanks in advance
Check all fuses.
you already checked diesel level.
charged the battery. can you jump start from another car?
to be 100% sure its not the battery?
when i had this similar problem sith my 2.0 tdi 3 years ago.
the battery, starter motor and 2 injector seals where replaced.
If the battery can only spin it for a min or two get a new battery first.
Buy a KOBA from Partmaster, cheap and very good quality.
spooln
I think BB is right. We had starting problems on a golf, lots of mucking around, and then vanished with a new battery.
ranton-inc
That reminds me i need to go pickup a new koba today
Sent via Tapatalk
6evil9
i also tried to jump start with other car (mitsi colt)
same effect
i suspect no diesel gets into engine (drained out when parked uphill?!)
i also read some stories about "non-return valve" needs to be fitted,  can this be the case? [no idea why it is not factory fitted though if this can be problem]
i guess i can try to get new battery, and if no luck return it... don't want to be investing in $250 battery to find out it is not the cause...
the phantom
replacing a 6 year old battery insn't necessarily a waste of money, more of an investmnent IMHO
ranton-inc
If your battery isnt steong enough your glow plugs wont preheat properly and ur engine will endlessly crank and not start
Mine does it when i forget to let it preheat
Sent via Tapatalk
6evil9
how long does it usually preheat?
any way to find out if i got diesel in the engine?
The Koba batterys are not that expensive I don't think.
They need to crank at a certain speed to build enough compression to start.
If your battery is weak buy a new one.
I have seen so many people fail at jump starting.
Did it crank hard and fast with the jump?
00quattro00
Quote from: ranton on September 25, 2012, 01:15:39 PM
Sent via Tapatalk
Modern tdi engines dont even need glow plugs for our climate
ranton-inc
Quote from: 00quattro00 on September 25, 2012, 04:39:33 PM
yeah but if you dont let them do their thing and crank the engine usually wont allow it to start if i throw the key in and push start without letting it do its glowplug thing it causes a non start..
(But then again im quietly inclined to believe my battery is nearing the end of its useful life which is probably another contributing factor)
5-pot
I don't suppose you have a 125kw motor?
There was a lot of grief with injectors going on the GT TDIs here in Australia.  Don't know if NZ cars had the same issue.
But then I think 2006 is a bit early to have the 125...  I think they only came out in '07 when DPFs became standard.
- 1990 Coupe quattro - R.I.P.
- 2005 Golf 2.0 TDI
Fizz
have you scanned the car for fault codes?
5-pot
Quote from: Fizz on September 26, 2012, 12:47:09 PM
Yeah, do what he ^ said.  But find someone with a decent VAG-COM.  Might get more info that way.
There's a few guys here with one so, hopefully there's someone who's local to you.
- 2005 Golf 2.0 TDI
