Author Topic: AUDI A6 Oil Pressure  (Read 1314 times)
Offline 88UH8
« on: November 14, 2012, 08:34:12 pm »
Hey people, my 1998 A6 Oil Pressure Low light came on and im not too sure what to do. I dont have an owners manual :/
Help anyone?
Offline Andy_007
Re: AUDI A6 Oil Pressure
« Reply #1 on: November 14, 2012, 08:47:26 pm »
If its the red oil can flashing light thats seriously low oil pressure or a faulty sensor/wiring. Is the motor running rough/noisy, is oil level okay ?
2007 Audii A4 Quattro 3.0TDI
« Reply #2 on: November 14, 2012, 09:38:28 pm »
Its either low on oil or the sender unit is toast or your oil pump is bust which is rare.
« Reply #3 on: November 14, 2012, 10:30:50 pm »
What engine? Could be sludge build up, it is very rare for a oil pump to fail
« Reply #4 on: November 15, 2012, 09:10:09 pm »
Ive had a oil pump relief valve stick and oil pissed out the side of the oil filter at like 300psi
Oil filings in the oil from a flogged out crank shaft thrust bearing.
Offline 88UH8
« Reply #5 on: November 16, 2012, 09:06:24 pm »
The engines running smooth as! Oil was a bit low though, I put some in and the light didn't pop up again. However I think it is running rich on oil generally. It has a 2.4 V6 non 4wd.
