Up grading my 200 Avant
Started by 00quattro00, December 12, 2012, 09:02:13 PM
00quattro00
Quote from: slowburn on January 22, 2013, 05:08:25 PM
i have a UR intake manifold and airbox,that'll fit to this aye? what'll do for the exhaust mani and down pipe?
Yep they will work. Just use the turbo mani you have. The are the  between models
Sent from my GT-N7100
Quote from: 00quattro00 on January 22, 2013, 04:55:46 PM
Staying petrol. Using the talldeck diesel block to go to 2.5l
Basil.....................you sure your not over doing it?
There is lots of other work to do on that old beast sunshine :)
But I'm looking forward to seeing if you can make something out of this.
00quattro00
Im no where near being over it.
A mate is building a 2.5 10v for his ur so I decided to do the same
M
Just out a proper engine in it and have 2.8 litres.  ;D
00quattro00
Quote from: M on January 22, 2013, 07:42:55 PM
I havent bought a boat yet
M
Quote from: 00quattro00 on January 22, 2013, 07:56:37 PM
Boat anchors can pull cars along well!!!
slowburn
how many horses is the KG pushing out?
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
00quattro00
Quote from: slowburn on January 22, 2013, 09:56:53 PM
Standard they are 185 odd. But they  hardly even boost.
slowburn
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
00quattro00
Quote from: slowburn on January 22, 2013, 10:05:25 PM
how hard to get to 200?
Easy. Just up the boost a bit. They only boost like 7psi standard
slowburn
what does it come with,what do i need to source to make it run
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
00quattro00
Quote from: slowburn on January 22, 2013, 10:16:54 PM
Its just a bare block basically
00quattro00
There is a complete 200t in welly tht im going to check out on the weekend so could probably supply a complete engine
00quattro00
#33
Have bought a 100 turbo as a donor car, main reason is that its only done 130km and its mint, no leaks from the rack or power steering pump, heater and aircon work and it has an mc2 engine (last of the 10vt with the best cis). Will swap all the good bits into the avant along with quite a few goodies from 034, then later on change to efi and fit my turbo manifold
Will be spending everything I get from the jetta and more on it  :P Will be the best 200
slowburn
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
200s avants are awsum.
Lower it a bit.
00quattro00
00quattro00
Bought the donor home, can't believe how tidy it is and how well it drives
slowburn
99 B5 S4 Avant
85 coupe quattro
72 fiat 124 coupe
97 corolla wagon
00quattro00
Na palmy. There is a guy in karori with a fwd 200 turbo.
