Author Topic: Up grading my 200 Avant  (Read 7060 times)
Re: Re: Up grading my 200 Avant
« Reply #20 on: January 22, 2013, 05:40:44 pm »
i have a UR intake manifold and airbox,that'll fit to this aye? what'll do for the exhaust mani and down pipe?
Yep they will work. Just use the turbo mani you have. The are the  between models
Sent from my GT-N7100
« Reply #21 on: January 22, 2013, 06:42:28 pm »
Staying petrol. Using the talldeck diesel block to go to 2.5l
 Basil.....................you sure your not over doing it?
 There is lots of other work to do on that old beast sunshine :)
 But I'm looking forward to seeing if you can make something out of this.
« Reply #22 on: January 22, 2013, 06:45:03 pm »
Im no where near being over it.
A mate is building a 2.5 10v for his ur so I decided to do the same
Offline M
« Reply #23 on: January 22, 2013, 07:42:55 pm »
Just out a proper engine in it and have 2.8 litres.  ;D
« Reply #24 on: January 22, 2013, 07:56:37 pm »
I havent bought a boat yet
Offline M
« Reply #25 on: January 22, 2013, 08:35:30 pm »
Boat anchors can pull cars along well!!!
Offline slowburn
  • how many is too many?
« Reply #26 on: January 22, 2013, 09:56:53 pm »
how many horses is the KG pushing out?
85 coupe quattro
85 coupe GT
72 fiat 124 coupe
97 corolla wagon
« Reply #27 on: January 22, 2013, 09:59:34 pm »
Standard they are 185 odd. But they  hardly even boost.
Offline slowburn
« Reply #28 on: January 22, 2013, 10:05:25 pm »
how hard to get to 200?
85 coupe quattro
85 coupe GT
72 fiat 124 coupe
97 corolla wagon
« Reply #29 on: January 22, 2013, 10:12:32 pm »
Easy. Just up the boost a bit. They only boost like 7psi standard
Offline slowburn
« Reply #30 on: January 22, 2013, 10:16:54 pm »
what does it come with,what do i need to source to make it run
85 coupe quattro
85 coupe GT
72 fiat 124 coupe
97 corolla wagon
« Reply #31 on: January 22, 2013, 10:27:01 pm »
Its just a bare block basically
« Reply #32 on: January 24, 2013, 08:32:39 pm »
There is a complete 200t in welly tht im going to check out on the weekend so could probably supply a complete engine
« Reply #33 on: May 10, 2013, 08:50:35 pm »
Have bought a 100 turbo as a donor car, main reason is that its only done 130km and its mint, no leaks from the rack or power steering pump, heater and aircon work and it has an mc2 engine (last of the 10vt with the best cis). Will swap all the good bits into the avant along with quite a few goodies from 034, then later on change to efi and fit my turbo manifold
Will be spending everything I get from the jetta and more on it  :P Will be the best 200
« Last Edit: May 10, 2013, 09:02:54 pm by 00quattro00 »
Offline slowburn
« Reply #34 on: May 11, 2013, 12:22:38 pm »
nice
85 coupe quattro
85 coupe GT
72 fiat 124 coupe
97 corolla wagon
« Reply #35 on: May 11, 2013, 02:42:40 pm »
200s avants are awsum.
 Lower it a bit.
« Reply #36 on: May 11, 2013, 04:28:05 pm »
 Lower it a bit.
Will be getting a set of these
http://2bennett.com/body_5000_200_suspension.html
« Reply #37 on: June 02, 2013, 09:37:19 am »
Bought the donor home, can't believe how tidy it is and how well it drives
Offline slowburn
« Reply #38 on: June 02, 2013, 11:27:35 am »
from karori?
85 coupe quattro
85 coupe GT
72 fiat 124 coupe
97 corolla wagon
« Reply #39 on: June 02, 2013, 12:19:59 pm »
Na palmy. There is a guy in karori with a fwd 200 turbo.
