Heavy duty clutch
Started by 00quattro00, December 27, 2012, 05:50:44 PM
00quattro00
Does anyone localy supply an uprated clutch for an 020? Or is it an overseas order?
watercooled
Stock clutch is pretty tough,what sort of power are you wanting to run thru it ?,found after a few clutch jobs the pressure plate will normally do another turn if not chewed up,by a new oem disk and a f/wheel resurface and you will be good.
The clutch disk is real cheap from the states,remember to replace the release plate and spring,thrust bearing also.
2002 T4 transporter 2.5 TDI.
00quattro00
Quote from: watercooled on December 27, 2012, 10:11:18 PM
Will need to hold atleast 180hp,
The Sach set up from Platinum and maybe Dubshack? Is the best you can do.
I had a carbon/kevlar from Autoclutch but I would just buy the Sach if I did it again.
