Author Topic: Convert Stereo to Mono in a Car Stereo  (Read 155305 times)
Offline dubstar
« on: January 15, 2013, 11:17:30 am »
As mentioned in my project thread, I need to convert from stereo to mono, so I can run just one speaker in the factory location.
I found a simple wiring diagram (see below) that apparently can convert stereo into mono, however I have found that it distorts the sound and also really limits the volume.  Can any of the electronics experts here tell me another way to get around this?
If I read the schematic correctly, I put resistors on all 4 wires (R+, R-, L+, L-) and then 1 big one between them.  I have used std type resistors rated at 1W.
Schematic:
My wiring:
Offline Pristle
  • vyf ster
Re: Convert Stereo to Mono in a Car Stereo
« Reply #1 on: January 15, 2013, 05:20:23 pm »
This is digging into the memory banks. I needed something similar 30 years ago for my Beetle.
You're on the right track I think. Look at this option:
or the one shown here: http://jwsoundgroup.net/index.php?/topic/7015-passive-summing-stereo-to-mono/
I remember adding caps in the circuit I used way back when. Which helped with tone and volume loss.
« Last Edit: January 15, 2013, 05:27:42 pm by Pristle »
Offline Gordo
« Reply #2 on: January 15, 2013, 06:22:31 pm »
Was going to mention volume - if the original speaker is being used, it's probably rated for around 6W, maybe more, and the head unit may be overdriving it if you're not careful.
Offline qta4
« Reply #3 on: January 15, 2013, 07:51:22 pm »
Both of these circuit diagrams relate to input to the amplifier stage.
I thought you were taking about the output stage to feed the Speaker's.
What you have will not work at output.
Offline dubstar
« Reply #4 on: January 15, 2013, 10:06:37 pm »
Yes. I am talking about output straight into the speaker.  That revised schematic looks odd to me, they are grounding the return wires?
Will need to keep hunting.  What would be good is a bridgeable 2 channel amp that is tiny, maybe the size of the ashtray
