Author Topic: Finally got the Samco's fitted -found suspect oil leak.  (Read 1587 times)
Offline SimonS2
« on: January 31, 2005, 10:41:08 am »
Finally got the Samco silicone inlet hoses (from S2Central/S2Forum) fitted yesterday: pretty straightforward job, but skinned a knuckle or two getting the insane twisty turbo outlet / bypass pipe combination in.
Noticed some fresh oil on sump which appears to be coming from somewhere low on side of block: anyone know where that may come from? (it's impossible to see the source without taking the radiator off).
[attachment deleted by admin]
Offline SimonS2
Re: Finally got the Samco's fitted -found suspect oil leak.
« Reply #1 on: January 31, 2005, 09:51:26 pm »
Left side (passenger side) and low down on block.
longlife-rs2
« Reply #2 on: February 25, 2005, 02:07:09 am »
 ;D  Had same leak myself check centre of oil pressure sender plastic cracks and causes leak got a new one from GSF pig to fit
Offline SimonS2
« Reply #3 on: February 28, 2005, 09:52:17 am »
From what I can see that oil pressure sender could be it. May just get garage to look at it as getting in there looks like a major job to me.
