Author Topic: 1996 NZ New A6 Quattro Avant manual query  (Read 1393 times)
Offline Matt
« on: April 17, 2013, 06:21:19 pm »
Hi all,
Keen to check out this NZ New 1996 Audi A6 2.6 quattro wagon http://www.trademe.co.nz/motors/used-cars/audi/a6/auction-583257931.htm but couldn't see a diff-lock button by the handbrake,  VIR says it is actually a Front Wheel Drive but you can see the Quattro badges on the back and above the glovebox - owner informs me it is a quattro as has a rear diff.. any ideas about if the NZ New model came with the diff lock?
Cheers,
Matt
Re: Re: 1996 NZ New A6 Quattro Avant manual query
« Reply #1 on: April 17, 2013, 06:31:38 pm »
Hi all,
Cheers,
Matt
They dont have a diff lock
Offline Matt
« Reply #2 on: April 17, 2013, 06:35:13 pm »
Cheers for that.  Anything to look out for when checking it out?
« Reply #3 on: April 17, 2013, 06:40:52 pm »
Nothing major. They are really quite reliable. I have a 2.8 30v quattro wagon with s6 running gear. Aslong as it drives without any clunks it will be fine.
Offline Andy_007
« Reply #4 on: April 17, 2013, 07:12:45 pm »
Make sure the heater works and the heatercore isn't leaking into the footwell. Check all the functions of the climate control work. Oil leaks are pretty common from the valve covers and rear cam plug, also between the V of the engine. Check the power steering fluid is a dark green color and not red ATF. Ignition switches are pretty common to fail, key wont feel smooth when you turn it and sometimes wont release the key unless you turn it back to run, then try again, Replace before it fails completely, only buy genuine.
2007 Audii A4 Quattro 3.0TDI
« Reply #5 on: April 17, 2013, 07:22:14 pm »
Also its a 2.6, they only have 110kw, mine has 142kw and is ok, i wouldnt want any less
Offline Andy_007
« Reply #6 on: April 17, 2013, 07:38:13 pm »
You seen that green one been wrecked on trade?, if you need some parts. i think its a 30V. Might look into seeing what they want for the motor+gearbox+wiring loom
