Measuring air/fuel with VAG COM
Started by coons, July 27, 2013, 02:54:34 PM
coons
Hey guys
I found a spread sheet on the Ross Tech website to measure air/fuel using VAG COM which is handy. I don't quite get something though and I am hoping someone can assist me.
Here is the pre-made spread sheet: http://www.ross-tech.net/vag-com/examples/air_fuel_EXAMPLE.xls
Seems simple enough, you copy/paste the exported block 2 data into the four blue columns on the left and then it calculates your AF on the right. However in the second blue column it has 'Engine Load' which it says is measured as a percentage. But VAG COM exports engine load as a 'm/ms' measurement which results in completely whack calculations.
Help? Anyone familiar enough with those block 2 measurements to know if it can be changed? Or how I would covert the exported values to a percentage?
