Author Topic: CANBUS VagCom VCDS available in Wellington  (Read 2100 times)
Offline NOWAY1
« on: August 16, 2013, 10:15:41 pm »
I'm up and running with CANBUS enabled VCDS in Lower Hutt. Able to scan and clear codes and will be getting into programming and canbus gateway upgrades within the next two weeks when my workload permits and the parts arrive. I'm fully mobile so I can come to you if required. OBD2 only at present, but I'll look into getting an adapter if there's a demand for it with older cars.
PM or txt 0275022583
Offline NZGTI
Re: CANBUS VagCom VCDS available in Wellington
« Reply #1 on: January 10, 2021, 09:43:07 am »
Hi There....I've just bought a 2.0 FSi and the Cruise control does not engage.....could I get you to run a scan on it?.......Is probably worth a 6pack for you.
Will be good to do it soonish so I can talk to the vendor about what needs to be done to fix.
2015 Golf 1.4 TSi
2006 Touran 2.0
2006 Golf GTI...gone
2007 Touran 1.4 TSi Stage 1...gone
2003 Passat v5...gone
1999 Golf GTi...gone
1990 Corrado x2...gone
1984 Golf GTi...gone
Offline NZGTI
« Reply #2 on: January 10, 2021, 10:03:59 am »
LOL... just noted the date on that post....was a few years ago...
Anyone else in WLG able to do a quick scan on my 2.0 FSI?
I'm in Lower Hutt
2015 Golf 1.4 TSi
2006 Touran 2.0
« Reply #3 on: January 11, 2021, 12:12:23 am »
Yup iím based in Lower Hutt but not back til the 17th. PM me if you can wait til then.
Current: 2004 MK4 R32
Past: 2010 MK6 GTI / 2007 B7 RS4 / 2006 MK5 R32 / 2005 MK5 GTI / 1998 MK4 GTI / 1997 B5 A4 MTM
Offline NZGTI
« Reply #4 on: January 14, 2021, 11:03:45 am »
I'm all good...Noway1 got in touch and I bought his VAGCOM off him....quite a bit to learn...seems a very powerful tool
2015 Golf 1.4 TSi
2006 Touran 2.0
Offline The Red Warrior
« Reply #5 on: January 14, 2021, 01:56:08 pm »
If you got the older unlimited cars version, then you got a sweet score.
« Reply #6 on: January 14, 2021, 07:38:03 pm »
Nice, good stuff!
It would be, Faran was my go to a few years back when I didnít have my own VCDS!
