W8 Passats - People bag them a lot, can anyone shed light on this?
Started by sifty, September 23, 2013, 07:16:00 PM
sifty
Ok, so I know that lots of people rag on the W8 Passat, but on paper it still seems like a great car.
I know that the oil filter screens on the supply to the cams is "too fine" and prone to blocking causing it to disintegrate and can cause some serious engine issues.  I've also heard the transmissions can crap out.
Does anyone have first hand experience with these issues and are they a good reason to avoid buying these cars forever?
Thanks,
Si.
spooln
Can other engines be fitted in as they have top spec everything...?
M
I have a NZ New W8 6 speed manual station wagon here and all the bits to do a VR6 swap with a suitably large turbo. Struggling for the time to be honest so am in the middle of readying the W8 to go back in.  :-\ :-\
W8 are ok, but the variator issue is a big one, but I haven't seen one in around 4 years now.... maybe all pretty much sorted already. Trans fault is the torque converter lockup clutch, engine out and torque converter overhaul($500ish), obviously not an issue on manual.
Silly little things like 02 Sensors are engine out to replace etc....
I have one at moment with map controlled thermostat fault..... $600+GST part and 4 hours to change, so there is $1000.
Decent cars when running right, nice and smooth and torquey, not what I would call "fast" though.
RS
One of these with a Chevy LS would be awesome.
Also, I hear that they have awesome traction in the snow and are the vehicle of choice amongst professional driving instructors  :angel:
mattpassat
Yep, I just traded mine in. While owning I had the cam adjuster issue, which was repaired under warranty. If its taken to the right people its not that bigger deal, can be repaired without removing engine. Mine was done in a day.  I really loved the car, I did the exhaust and lowered it. Its a heavy car though and slow transmission . I feel the vw build wasnt up to spec to many cheap parts wear out, suspension wears quickly also bushes etc. Let me know if you have any questions.
I do miss the 4 wheel drive
I changed to bmw 335i m sport wagon
Cheers Matt
Apparently several shops have dropped the little collets or whatever they are called into the motor like on Noj one. OUCH.
Robb46
I have a W8 and yes the cam timing adjustment valves started to became a problem, when the filter disintegrated. As soon as the problem started I stopped driving the car, this saved lots of damage. The mechanics were able to remove all the valves clean them out and flush the engine, $600, got away with it.
This car is now going better than ever, it has more power and is more economic to run. Got to love that.
I still love the W8 for what it is and what it will be in the future.
2004 Passat SW W8 Love It
5-pot
- 1990 Coupe quattro - R.I.P.
- 2005 Golf 2.0 TDI
GorGasm
The problem is that the Audi/BMW equivalents are better vehicles, especially the 540i.
