Author Topic: 1996 Audi RS2 Brilliant Black  (Read 94746 times)
« on: November 03, 2013, 12:29:22 pm »
Well I bought it on Friday 1/11/2013  :D
Just a quick post, I will add more detail later. Seems the past two owners have cared for it well. Ocular spent at least $4000 on it when he had it. Last owner has done cam belt, front brakes, alternator, suspension top mounts and wheels. The reason for the non-standard wheels is one of the orginals is slightly bent. It has quite new GY GDS3 tyres all around. I have the originals so that's something to sort at some stage. The car drives beautifully and the engine is silky smooth. The gear box feels spot on. I think a radiator might be on the way out though.
It has an aftermarket diverter valve so I want to check that out some time and make sure it is working properly. Apart from that it has an aftermarket radio - I don't like the look of it but it has MP3 input so will see how it goes. And of course in has a Link G4 ECU. Fogs and park lights are also aftermarket. Apart from that it appears standard and seems a very honest car. I believe it's the only 1996 model year RS2 in NZ. Service history is very patchy but will contact Giltraps at some stage to see what they have on it. It seems it may have spent much of it's life in Taranaki.
Anyway, I'm like a kid in a candy store at the moment. Plans are to drive it regularly and look after it as best I can. The existing fleet will remain. Very excited but lots to learn!
Specs:
« Last Edit: July 14, 2017, 12:33:15 pm by le mans »
Re: 1996 Audi RS2 Brilliant Black
« Reply #1 on: November 03, 2013, 12:32:08 pm »
Pics:
« Last Edit: July 14, 2017, 12:36:39 pm by le mans »
« Reply #2 on: November 03, 2013, 12:36:40 pm »
Original wheels:
« Last Edit: July 15, 2017, 12:53:38 am by le mans »
« Reply #3 on: November 03, 2013, 12:37:31 pm »
Nice!
2011 Mercedes C200 Wagon
Offline slowburn
  • how many is too many?
« Reply #4 on: November 03, 2013, 12:43:21 pm »
dope,was hoping this would make it into the fold on here somewhere......well done
« Reply #5 on: November 03, 2013, 01:16:58 pm »
Well done!
17 porsche 991.2 GT3 clubsport
Offline weta.worker
« Reply #6 on: November 03, 2013, 01:47:35 pm »
well done!!!!
:D
1994 RS2 GUARDS RED
2001 RS4 NOGARO BLUE
« Reply #7 on: November 03, 2013, 03:20:32 pm »
Awesome Jon, well done! Good to have another RS2 on the forum.
Two MY1996 RS2's were sold new in NZ, though the other one (RS Blue) was exported to OZ.
Offline ritmo
« Reply #8 on: November 03, 2013, 03:58:42 pm »
Nice... I went on tm to see if it sold. It had obviously.  Good price
« Reply #9 on: November 03, 2013, 05:49:19 pm »
Fantastic - another RS2 / RS4 combo owner on the forum!
Offline mjh
« Reply #10 on: November 03, 2013, 06:59:34 pm »
Welcome to the RS2 club.
« Reply #11 on: November 03, 2013, 09:26:01 pm »
Thanks fellas  :)
Ok, so radiator is leaking when warm. Is this a standard Audi 80 unit?
Diverter valve. Is it forge?
Fuse box. Seems a couple might be missing? The cigarette lighter doesn't seem to have power (for my portable vacuum cleaner)
I believe it has uprated injectors. The previous owner also changed all the coil packs.
I'm used to seeing pink coolant additive. Is this the wrong spec?
Few drops of fluid (hydraulic?) under front left of car from sitting overnight:
Looks like something down here too:
Rear luggage cover is in a bad state:
Aftermarket radio:
« Last Edit: July 15, 2017, 01:02:55 am by le mans »
« Reply #12 on: November 03, 2013, 09:31:31 pm »
2+2 vcds connector. I knew it would come in handy one day:
Only 1 fault stored - suspect due to battery being disconnected at some stage. Didn't return after clearing:
I haven't been able to communicate with the G4 ECU yet. The first app I downloaded said the ECU was too old, and the old version of the app I downloaded after said the software was too old  :-\ Any ideas? I believe the ECU is a G4 of some sort. Access looks a bit tricky - up behind the clove box somewhere.
« Last Edit: July 15, 2017, 01:09:12 am by le mans »
Offline weta.worker
« Reply #13 on: November 03, 2013, 09:46:30 pm »
http://www.s2forum.com/
is your friend (or your worst enemy!)
:D
1994 RS2 GUARDS RED
« Reply #14 on: November 03, 2013, 09:50:49 pm »
A couple of other minor things. The engine under tray is not fitted. It has a bit of a crack in it but not too bad otherwise. Will probably re-fit at some stage but not a biggie. A nice little bonus is remote central locking, which was fitted by a previous owner.
The paint work looks its age despite the pics (pics always bring out the best in a car's paint don't they). Will see if Gordon (final touch) would like to have a crack at it some time soon. Also plan to get the car serviced as last oil change was around a year ago and want to get it thoroughly checked over before I drive it too much. It did fly through a VTNZ WOF last Friday which is saying something!
« Reply #15 on: November 03, 2013, 09:52:27 pm »
:D
Thanks, I'll subscribe to that.
« Reply #16 on: November 03, 2013, 09:56:21 pm »
What's your plans for it? Keep it stock or lean on it a bit?  >:D
« Reply #17 on: November 03, 2013, 10:22:45 pm »
Time will tell lol. It's apparently running stock boost at the moment (20 PSI tapering to 16?). I will try and get all the niggles sorted and drive it as is before I decide whether or not to turn up the wick. I've only done 25km in the thing so far! I might see if I can get it on the dyno on the 30th. Bit tricky as I'm working. My boy loves to see the cars on the dyno so maybe his mum will bring him along  ;)
« Reply #18 on: November 04, 2013, 07:34:04 am »
Jon, this is what my fuse box looks like:
Does yours have a sticker on the fuse box?
To answer a couple of questions:
I not sure if a standard Audi 80 has two radiator (I wouldnt think so, but a 5 cylinder may do?)
I dont know about the DV.
The injectors look the same to me (green in colour).
You are right, the coolant should be pink, G12 or whatever its called?
Also, do you have the Porsche/Audi hand book?
« Reply #19 on: November 04, 2013, 07:37:02 am »
Oh, and I guess you know it has the wrong gear knob?
