$2k to spend.
Started by itsta, May 20, 2006, 10:32:45 PM
Simon MkII
Well he's talked to all of us at CCS parts now! Neil was helping you with the chip and you talked to me the day before about wheels, mats and bodykits.
Mazda Mx5
Quote from: 16vGTI on May 23, 2006, 07:39:24 PM
Thought it would have to be one of you guys.
itsta
Thanks for the help guys.
Just had a couple of other very mundane questions.
My Golf is operating at 90degrees is this about right?
Also, how long can you keep driving for after the petrol buzzer and light comes on. (thats always good to know).
And i got 530km from my first full tank. Is that about how many k's i should be getting.
Cheers.
cao
90 Yes
Petrol Buzzer dunno alway fill up (First time test driving a golf on the way back the buzzer came on gave my such a fright thought it was going to blow up or something)
K's Per tank sorry I don't pay much attention to it.
hitmanGTI
Quote from: cao on May 29, 2006, 08:45:00 PM
90 Yes
Your reserve from when the light comes on is about 7-8 litres...
Audi-man
Quote from: cao on May 21, 2006, 11:48:13 PM
They can be tuned to give more power than u can use
With my chip my wheels break loose in second  >:D
So cao, your happy with your wett chip and forge DV experience too. Being 4WD, I can't experience wheel spin. What did the clutch set you back?
hitmanGTI
Quote from: Audiman on May 29, 2006, 09:40:30 PM
My Clutch is going in tomorrow..
1200 Installed..228MM Single massed fly wheel VR6 Clutch
Steves S3 4 Wheel Spins in the wheel..  when accelerating hard..
hitmanGTI
how ever i dissagree with the more power than you can use comment..
I still think they could be far more powerfull...
cao
#28
Yes happy  ;D
Clucth thread
Im not saying the chip is more power than you can use I was trying to imagine what an APR 3+ would be like.  What gear would it spin in with 300-350hp
hitmanGTI
hmm.. when the clutch goes in today.. i will probabaly be investing in a boost controller and upping the tempo to around 17lbs
cao
hitmanGTI
i figured it can handle it..
plus i still got a spare turbo..  ;D
failing that.. ill buy a K04
cao
Is not more likly to run lean if you up the boost via a manual process.
hitmanGTI
Quote from: cao on May 30, 2006, 08:02:30 AM
nah ill just put a higher pressure FPR in make it run a touch richer..
Turbo
Quote from: MK4 GTI on May 29, 2006, 10:00:50 PM
really? that's odd. perhaps his haldex system is poos
hitmanGTI
Quote from: Turbo on May 30, 2006, 02:22:32 PM
or maybe your S4 just isnt powerfull enough..
minds you its in the wet that it brakes traction :D
Turbo
Quote from: MK4 GTI on May 30, 2006, 02:39:48 PM
touche.
steve's turbo must be quite peaky ... or is the car too heavy? ... :P ;)
yeah and that's all 4 wheels at once. ;D.
hitmanGTI
Quote from: Turbo on May 30, 2006, 04:05:09 PM
touche.
maybe your ego is..
Turbo
hitmanGTI
Quote from: Turbo on May 30, 2006, 04:15:57 PM
is what?
:p i dunno just coulnd think of anything else to say at the time..
