Author Topic: 6N2 Polo GTI box is toast  (Read 3055 times)
Offline the phantom
« on: January 17, 2014, 04:06:56 pm »
I don't have a lot of info at this stage, but it seems my son's 2001 Polo GTIs gearbox is stuffed and unrepairable (I need to check that out), new box $4k
so thoughts are check out locating a second hand box to swap in (hen's teeth and probably same issues) or maybe putting a MK3 Golf GTI 16v engine and box in
I'm away from home at present and will check out UK Polos when I get home, any initial thoughts fellow vaskers?
Re: 6N2 Polo GTI box is toast
« Reply #1 on: January 17, 2014, 04:58:16 pm »
crap :(
« Reply #2 on: January 17, 2014, 05:46:21 pm »
Import box from UK, however someone on TM is wrecking a GTI as well
« Reply #3 on: January 17, 2014, 09:31:00 pm »
Has the diff gone into self destruct mode?
Offline choppy16v
« Reply #4 on: January 18, 2014, 09:04:50 am »
abf it!!
Re: Re: 6N2 Polo GTI box is toast
« Reply #5 on: January 18, 2014, 09:47:51 am »
Offline the phantom
« Reply #6 on: January 18, 2014, 01:32:08 pm »
I'm away and haven't had a chance to talk to my son about it yet, it's driveable, so possibly not the diff
I reckon a 1.8T would possibly be too heavy and unbalance the car, I do know they went into later Polo GTIs though
Offline SOFTLAD
« Reply #7 on: January 18, 2014, 06:08:29 pm »
You should talk to CBRT re sourcing you one in the UK and shipping it or talk with JohnP about rebuilding the existing box.
« Reply #8 on: January 19, 2014, 09:33:43 am »
I think this is pretty common for these gearboxs isnt it?
Offline the phantom
« Reply #9 on: January 19, 2014, 11:33:10 am »
thanks for the leads, I've dealt with John on a couple of occasions
I think it might have been Jem who described these boxes as being made of chocolate
« Last Edit: January 19, 2014, 11:36:22 am by the phantom »
Offline b0000st
« Reply #10 on: January 20, 2014, 08:31:56 am »
Someone was quoted $4000 for a box in NZ for my Polo so they traded it,  I got one in the UK for 75 pounds even with shipping its less than a second hand one here.
Matt
Offline HaNs
« Reply #11 on: January 20, 2014, 08:21:56 pm »
Yeh they are pretty weak boxes, what's it doing?
« Reply #12 on: January 20, 2014, 08:22:46 pm »
Convert it to auto  :P
Offline the phantom
« Reply #13 on: January 22, 2014, 01:09:24 pm »
had a chat with the guys at Vodis today, it's pulling to the left (pretty much a constant and we've had the alighnment done twice) but on the brake testing rollers with the car in neutral, the right wheel would suddenly lock with no apparent cause
sounds to me like a diff issue, if it was the 5th gear plastic bushing, I'd expect it to affect both wheels
while there are plenty of references to busted 6N2 GTI boxes (one guy on UK Polos had 5 boxes fail on him, sounds like good money after bad) but there's precious little on fixing them other than getting them rebuilt at Joe Bloggs Motors who are better at it than Fred Smith Autos
there's a press on final drive and a riveted one, could be a rivet's come loose
Mike at Tristram referred me to Mike at Kaspa Transmissions to get an honest appraisal
Offline HaNs
« Reply #14 on: January 22, 2014, 01:29:33 pm »
Dads one which i had for a few months always pulled to the left even after new tyres and alignment. Didnt look further into it.
It also had a bad crunch into reverse, girlfriend drove it one day and it was fine after then  ???
Might be worth talking to a local box expert
Offline HaNs
Offline the phantom
« Reply #16 on: February 13, 2014, 08:58:06 pm »
thanks Hans, but not needed (fingers crossed), I took it to Kaspa Transmissions on the advice of Mike at Tristram and their view was that the box wasn't the problem and to get the brake issues sorted and then to reassess the issues
so took it to Endeavour Motors who replaced rotten brake vacuum hoses and fitted new front discs and pads, they checked the gearbox oil and said it looked good, so I picked up the new passenger's door lock from TGristram today and will probably fit it on Saturday, then off to the testing station for a WOF check
Offline the phantom
« Reply #17 on: February 16, 2014, 11:14:45 pm »
fitted the new lock yesterday, finished too late to go to the testing station, went today and with the replacement of a tailight bulb - flew through
so much for a $4,000 gearbox replacement   :P ::)
« Reply #18 on: February 17, 2014, 08:45:40 am »
Great result!!
Offline the phantom
« Reply #19 on: February 17, 2014, 05:41:44 pm »
the battery was a bit flat as it had sat for a while, so I took it on a run up to Albany and back, on the uphills at 100K it was shuddering a bit,
talked to Steve at Endeavour when i took my Golf in for a warrant and he said it was most likely inner CV joints and it might go away with a repacking of grease
a quick google didn't show up anything useful, is this an easy job?
