Author Topic: What does ISOFIX look like and does my 2003 S3 have them?  (Read 2862 times)
eddyg
« on: July 05, 2006, 11:38:16 am »
Hi,
On occasion I want to fit a baby seat in my S3. I was hoping to use ISOFIX rather than the seat belts. Does anyone know whether ISOFIX is standard on S3s or whether I have to get it fitted? I'm not sure what to look for in the seat, nothing is obvious..
Cheers, Ed.
dimistyle
Re: What does ISOFIX look like and does my 2003 S3 have them?
« Reply #1 on: July 05, 2006, 12:34:36 pm »
If you can't see anything obvious under the seats you probably don't have them installed. My 2003 Passat doesn't have them either :o.
Just get the child seat anchor point installed onto the rear of the seat as VAG recommend. This way you can install any NZAUS standard childseat into you S3 anytime you need to. Most installers should only take an hour to do this.
Anyone know any recommended installers in CHCH, or do RETRO have a branch down south?
Neil_Corrado
« Reply #2 on: July 05, 2006, 12:51:58 pm »
ISOFIX isn't anything obvious. If you like PM me your chassis number or registration number and I can tell you.
dimistyle, you can retro fit ISOFIX to your Passat if you dont have it.
Neil
« Last Edit: July 05, 2006, 12:58:59 pm by Neil »
eddyg
« Reply #3 on: July 05, 2006, 01:15:22 pm »
Neil
Hi Neil,
I lifted the seat bottom up and I see two little blue bars at the back, are they ISOFIX? Or are they just anchor points for where ISOFIX goes.. I'll PM you my details I guess for confirmation.
I've got a second car (Toyota Granvia Van), is it possible to retrofit ISOFXI to that as well?
Thanks for your help - I'm quite new to this baby thing :)
Cheers, Ed.
Neil_Corrado
« Reply #4 on: July 05, 2006, 03:54:00 pm »
Hi Neil,
Cheers, Ed.
The little blue bars are the ISOFIX anchors, the seat clips over those to secure it to the cars chassis.
I doubt you could fit it to the Toyota, as the anchor points need to be mounted to the chassis. The beauty of the AUDI/VW ISOFIX seats is that they can be used in non ISOFIX cars with the seat belt.
« Last Edit: July 05, 2006, 03:56:10 pm by Neil »
dimistyle
« Reply #5 on: July 05, 2006, 05:12:37 pm »
Thanks Neil, yeah I though about installing ISOFIX, but ended up buying a baby Factory carseat so it wasn't required in the end. Maybe when we need to go to a booster seat we can look at it again, as there are some nice Recaro/Momo and VAG seats available. ;D
« Reply #6 on: July 06, 2006, 05:39:51 am »
I had ISOFIX ancor points installed into our A4 Lemans. We then purchased a AU made Britax baby seat (with overstrap)
and got the optional additional ISOFIX strap. Its a good combination and way safer than pretty much all other setups that i have seen.
note, a friend of ours purchased a jap import golf, and that had isofix ancor points already.
18 Disco5 HSE
